Centerforce DFX
Will Can you shoot me a PM on how much a DF clutch and flywheel would cost. Right now I have a chatterbox Spec 3 with Fidanza alum flywheel. I'm only pushing 383 rwtq. I take the car to the 1/4 with 11.50" street radials and the lightweight set-up I have bogs every time I try to launch. Thanks.
1) DF017010 is our 11” Dual Friction that can be used with most after market flywheels as well as the stock flywheel. We recommend this clutch up to 550 torque.
2) DF395010 is our 12” Dual Friction that may not work with some of the after market Aluminum flywheels because some of the after market Aluminum flywheels use an 11” heat shield/friction plate. The 12” Dual Friction is a great daily driver that will hold some serious torque while maintaining excellent control. This is my personal favorite for these cars that running in the range of 400-750 torque levels.
3) 01017010 is our DFX assembly that is a six puc sprung hub disc. This DFX will not be as user friendly as our Dual Friction but will hold some serious torque numbers. We had a local guy dyno 979 lbs. torque at the wheels with his Vette that is road raced and street driven.
4) LM017010 is our Light Metal assembly that is an Aluminum Pressure Plate that is @ 6 lbs lighter than a stock pressure plate. The LMC was designed for the road race arena or the guy looking to reduce rotational mass. The Light Metal clutch works well in cars that are at the 650 and below torque range. The Light Metal pressure plate coupled with the DFX disc works great for the cars making 500 lbs. of torque and up. We have had a few guys hold in the 1000 torque range but wouldn’t rate the clutch to hold that consistently.
I hope this helps clear up any confusion with the product?
Will Baty
Centerforce Clutches
www.centerforce.com
Just wondering, what do you mean by not user friendlyon the DFX? Street wise or wearing out?? I'll be running a 500 HP car plus an additional 200 shot. Thanks.
I'm guesing it does..
FWIW I got mine, and I'm going to be using the stock LS2 GTO flywheel, which I'm told is a stock LS1/LS6 flywheel. The stock disk was roughly 12" so it should be fine right? It looks like everything lines up fine, the plate just needs to be turned and balanced.
There are a handfull of them in vegas around the 450-500 RWHP range, clutch rocks until you put real tires on it.
It's in my car around the same area.
This DF395010 sounds like the perfect street clutch for all but the highest HP cars and you can't beat the price! IF, however, I have to replace my flywheel too, that would change the picture and than I'd go with an LS7 setup...but at the cost of 10rwhp
Your stock flywheel and clutch should both be 12" IIRC.
I can guarantee you the OEM flywheel is not allready balanced. Spend the money and have it 0 balanced from a reputable machine shop.
First post of the page...
