Trans removal virgin
(1) Do I need to support my engine after I remove the trans? The trans will be out for at least 2 days.
(2) Is it necessary to lift the rear also?
Ive searched this topic like a ****, but I would appreciate ANY tips/advice on a clutch swap done at home. I WANT to do this myself, Im not being cheap. I will buy whatever I need. Thanks.
2) It is not necessary to lift the rear end
pulling it out is the easy part
You're right, pulling it out IS the easy part
. This helps as well for torque specs:
http://www.ls1howto.com/index.php?category=1
2) Have lots of extensions.
3)If for some reason you are not replacing the slave(YOU SHOULD REPLACE IT) you can pull the trans back a bit and remove it with a 10mm wrench to avoid bleeding the air out...some bleeding willl still be required...and dont overtighten these bolts, they are torqued to something like 25 INCH pounds.Check all torques and follow them.
4)Remove the shifter...not just the handle, the entire thing, then put masking tape or something over the hole to keep debris from getting in there.
5) Be carefull when removing the driveshaft, make sure the car isnt relying on the parking brake to hold it from rolling.
6) Carefull when removing the torque arm from the trans that it isnt "loaded", a jackstand under it is a good idea.
7) Support the oil pan with a scissor jack or something.
8)When installing it DONT FORCE IT, if it doesnt want to go in then its not lined up right.
9) Make sure your mother is not around cause some foul words and phrases are bound to be heard.
and this sounds dumb but almost everyone does it... DO NOT FORGET TO RELEASE THE CLUTCH FORK before you try and pull the tranny off.. cause no matter how hard you try it will NOT come off without doing this .. and it will save you alot of cussing..
hope this helps
hope this helps
Oh yea get ready to
cause **** happens. Good luck remember to drain the fluid.
