Tranny grinds when....
Total rebuild cost is typically in the $750 range (labor and parts). You can attempt it yourself, but you will need special tools which cost around $500 for the set.
Or, you can just live with the grind and keep beating on it until it no longer shifts at all and then do the rebuild. I raced a full season with 3 bad synchros, it ground like hell but seemed to shift just as quickly. lol
Tony
BTW: Im 100% sure this is a result of runing a Mclod clutch with stock 98 hydraulics. Not drilled or anything, and I have ground a few times going into third at 5k+ RPM.
<small>[ April 14, 2003, 11:38 AM: Message edited by: tigertat ]</small>
