Atf Poll
Old 07-05-2008, 08:35 AM
z_speedfreak's Avatar
Default Atf Poll
im about due for a fluid change in my tranny and im looking for a smoother shifting fluid. so vote for which fluid your the most pleased with.
Old 07-05-2008, 08:54 AM
man that sucks, my connection broke when I was in the middle of making the poll options... mods any way to continue the poll options?
Old 07-05-2008, 10:11 AM
Biggin'89's Avatar
i prefer regular valvoline dex III non-synthetic. i had the mobil synthetic aft in it but had syncro issues and couldn't power shift. its built to a stage 4 btw. so you may not have any problems with the synthetics.
also it seems alot of people like the honda atf.
Old 07-06-2008, 11:21 PM
scidav87's Avatar
i used Oreiley auto store brand with no probs at all, even with power shifting, had Royal Purpul in if before cltuch swap, gears grinding a bit right after putting it in, so i went back to a non synthetic...shouldn't be any reason to use a synthetic fluid in the t56...if you think about it?
Old 07-06-2008, 11:47 PM
Pontiacerator
RevGTO's Avatar
I went with Mobil 1 ATF because of the recommendation on Six Speeds Inc. I can say that now my synchros feel "dry" or rough - like they're not well lubed enough and not doing their job. Like the stuff is too thin. I don't have the smooth shifts like before ... and this is with normal shifting.
Old 07-07-2008, 12:37 AM
_JB_'s Avatar
Amsoil ATF
Old 07-07-2008, 10:06 AM
jmm98LS1's Avatar
Pennzoil Synchromesh
Old 07-07-2008, 10:26 AM
getusum's Avatar
Six Speed Inc. wants you to use red line atf.....I use 2 qts mobil 1 atf and 2 qts of synergyn lubricants....
Old 07-07-2008, 11:00 AM
sidewayz28's Avatar
ttt... want to know the same thing
Old 07-07-2008, 10:25 PM
Pontiacerator
RevGTO's Avatar
They may have changed their recommendation. This is from their post in the FAQ sticky:
Q: What transmission fluid do you recommend?
A: We use Mobil 1 ATF in all of our daily drivers. While Mobil 1 is what is desired some customers have trouble finding it in there locations. We also use GM Synchromesh. Royal Purple should not be used in a stock transmission as it has been known to cause premature blocker ring wear.
Old 07-08-2008, 08:49 AM
yeah I've heard the synthetic oils are no good for the stock blocker rings.. but what about CF blocker rings? my tranny aint stock either..
Old 07-08-2008, 08:57 AM
Ky_Dragracer's Avatar
I run Royal Purple
Old 07-08-2008, 11:30 AM
sidewayz28's Avatar
LOL at your avatar..
i heard royal purple sucks for stock T56..
anyways Syngear is no longer sold by six speed inc....?!
