pilot bearing
Just take a hammer and chisel and knock a slot in the pilot bearing. It doesn't take much effort, it's pretty weak metal. Just knock 1/2" of a notch on either side, needle bearings will fall out, shove in the puller, and yank that sumbitch out of there.
Do NOT use the grease method on an LS1 crank! (by the way, wet toilet paper works better than grease on solid core cranks) The LS1 crank is hollow, and you very well may send the crank oil gallery plug in to the oil pan (which someone here has done before, not to name names Zt*rd :p ).
-Andrew
Yes, you can see rods from the hole if there's no plug there, and oil does get slung up there.I had a bad pilot bearing in my '88 Mazda. It was squeaking at idle, especially when the clutch pedal was pushed in, but the noise went away when the clutch pedal was released and the car was in gear. The bearing had seized.
-Andrew
JR
but now i cant seem to get the tranny back in i used the alinment tool and it is ok what gives?
-Andrew
If you want to do it hydraulically, use a 3/8 extension and if it doesn't fit completely snug try wrapping some electrical tape on it. I'm sure this has been said but I'm too lazy to read it all. Good luck.
Cheers
cmac
