ls1 six speed into a lt1 auto car
Is this at all possible to put a six speed from an ls1 car into my 1994 z28 with an lt1? If so what all is needed to do this right now my car is a stock a4 and im looking to do the six speed swap. thanks everyone
oh alright i was just checkin just in case i run into a ls1 six speed for sale. Thanks for the info. Ill just keep my eyes peeled for a lt1 six speed then.
It wasn't hard at all. Besides cutting a hole in the trans tunnel for the shifter and a hole in the firewall for the master cylinder, it's a straight bolt-in swap. I got lucky and found someone to trade setups with straight up, so all I had to was buy the shifter I wanted along with a new master & slave......less than $300 for that stuff. Of course then I ended up having to rebuild the trans shortly after the swap b/c the synchros were shot.....that cost me $750 in parts. If you end up having to buy everything to do the swap (trans/bell, flywheel/clutch, pedals, crossmember, hydraulics etc), plan on spending around $2k. All the info you need to know to perform the swap is in the sticky at the top of this page.
