just installed ram powergrip clutch
I just had a RAM powergrip installed (wasn't doing this one on my back in the driveway
) and just wanted to see how many miles you drove for the break-in period before you starting beating on it. my cars running better than it ever has and i really want to take it to the track but im waiting to break the clutch in. I only put about 180 miles on it so far. The manual says 500-1000 miles of normal, unagressive driving but thats tough when you got all that hp under your right foot and the sound of a hurricane coming out the exhaust. just interested in hearing some opinions
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
im aproaching 500 miles shortly but i have had a few pulls on it against a 4.6 mustang still destroyed it. kinda smelled clutch but could be because its not fully broken in. i didnt shift hard just put it to the bondo once i was in the next gear
I Have Used 2 Of These,the 2nd & Last One Is In My Car Now With 4k Miles On It & 18 Track Passes On Et Streets Leaving On The Limiter At 6850rpm.i Did The 500 Mile Break In On Both Clutches & Still Barely Got 4to5k Before Slippage Began.good Luck!!'72 Ss Camaro Ls1 6sp,ms3,stg2.5 5.3's,fast92/92,4:11's.ran 11.53 With 1.7 60' & Clutsh Slippin At Arm Drop Live In Memphis.no More Rams In My Ride!don't Get Me Wrong It Grabbed Like A Big Dog For About 4k Miles.oh Ye The First One Spit A Spring Out & Lodged Between The Flywheel & Clutch,they Did Send Me A New Set Up That Lasted 4500 Miles.mostly Real Hard Street Driving/20 Track Passes On Et Streets Leaving At 6850rpm On The Limiter Side Stepping The Clutch!
I Have Used 2 Of These,the 2nd & Last One Is In My Car Now With 4k Miles On It & 18 Track Passes On Et Streets Leaving On The Limiter At 6850rpm.i Did The 500 Mile Break In On Both Clutches & Still Barely Got 4to5k Before Slippage Began.good Luck!!'72 Ss Camaro Ls1 6sp,ms3,stg2.5 5.3's,fast92/92,4:11's,470 Rwh.ran 11.53 With 1.7 60' & Clutsh Slippin At Arm Drop Live In Memphis.no More Rams In My Ride!don't Get Me Wrong It Grabbed Like A Big Dog For About 4k Miles.oh Ye The First One Spit A Spring Out & Lodged Between The Flywheel & Clutch,they Did Send Me A New Set Up That Lasted 4500 Miles.mostly Real Hard Street Driving/20 Track Passes On Et Streets Leaving At 6850rpm On The Limiter Side Stepping The Clutch!
