Hp limit for stock t56?
Still in the planning stages of my ls1 swap, and trying to find a tranny now. After looking at some pricing on 4L80's and torque converters, i got wondering about a t56. Question is, will a stock t56 take 450hp, or will i need to have some work done to it?
Sounds good guys. I'll get a price on a few peace-of-mind upgrades. What about a clutch? Can get the stock low-mile stuff with the tranny, but thinking about upgrading while it's apart. Any suggestions?
Broken shift keys have nothing to do with the power your car is making . I was talking more about actual breakage of parts like the gears and mainshaft . I see Corvette mainshafts fail around 650-700 rwhp but can snap with less power if the car gets bad wheel hop .
People run some rediculous times and power levels with a stock T-56. At 450 hp, you have nothing to worry about.
As far as a good clutch, look no further than TEXtralia. For your application the OZ700 Z grip would work good. Been running one for 2.5 yrs and over 20,000 miles. Hasnt missed a beat.
destroyed gears and snapped my mainshaft with a mere 450hp. No idea how that was enough power, I guess abuse over time can make stuff break. One to two shift = broken rear end which ended in a destroyed tranny. It could have been the weak link in the differential that caused my tranny to go. I guess the message here is, it really depends on your other weak links. A DTE brace could help you save your tranny incase you snap your differential.
My brother's went with just bolt-ons and mine went with 400ish rwhp (both start popping out of third gear and mine locked up in 4th after a high RPM run). The stock clutches also aren't good for much more than basic bolt-ons most of the time. If you're building a nice H/C car, I'd suggest looking into a low- to mid-level tranny from Six Speeds Inc and a decent clutch at least. Peace of mind is worth a lot of money in my eyes.
i'm still runnin my stock tranny w over 450rwhp but i had to rebuit part of it (with only 348rwhp and 355rwtq i broke it) cause it would kick outta third gear, then one night while racing a supra the damn thing locked it self in fourth gear and we had to roll it back in forth at a gas station to get it outta gear also they told me it was because my clutch wasn't fully dissengaging and when i power shifted it it bent the 3-4 shift fork, but im getting six speeds inc. to rebuild it strong soon. so if you run a stock one make sure you get a good clutch, stock clutches and power shifter will tear one up in a heart beat.
tex. clutches are pretty expensive, there are a lot of guys on here that run an ls7 clutch ( a lot of sponsors sell them) i put one in and i love it. an ls7 clutch should be good for 450, a lot cheaper too.
Seems to be hit and miss on whether it will take it or not. It is a take-out tranny out of a brand new gto, so maybe i'll just run it and see what happens. I don't drive it often or very hard when i do anyhow. I'll start looking for an LS7 clutch.
Already bought the tranny, and got a killer deal on it, which is why i thought i might spend a few bucks on some upgrades. For now i'll keep it stock and spend a few bucks on a clutch and shifter.
Oh, and sorry if this is a stupid question (i'm new to manual trannies), but what is the difference between an aluminum and steel flywheel? I know the aluminum is lighter, but is it more for racing than a streetcar?
i went with the ls2 flywheel(steel i think) aluminum is lighter and i see some people say better throttle response but the car feels smoother with the heavier (steel) flywheel, i like it a lot over stock. i've heard problems with people messing up the aluminum, if i were you i would go with the ls7clutch/ls2 flywheel combo, its cheap will hold your power fine. just think if it can hold the ls7 ok it will manage your car fine.
The aluminum flywheel is typically used more for auto x as it's lighter weight and winds out quicker, but from what I hear it doesn't hold the RPMs up as well on the shifts, which makes it, umm, less good for drag racing. But I've seen people run both. I stuck with the steel like most for drag racing.
