how do you gravity bleed a clutch???
Old Aug 29, 2003 | 02:21 PM
383ss's Avatar
Default how do you gravity bleed a clutch???
can you bleed it when it's already installed???
if so, how???
thanks!!
Old Aug 29, 2003 | 04:31 PM
theblur98ss's Avatar
Default Re: how do you gravity bleed a clutch???
Gravity bleeding is simple. Didn't work for me but here's how it works. You open the bleeder on the slave and just let it open. Stand there and the fluid will slowly seep down from the reservior. Make sure the reservior doesn't go dry. Fill it every 5 or 10 minutes I'd say. Try this for a half hour. It may work if there's just a little air in there but definately won't work for a new system or master. At least it didn't for my mcleod master.
Old Aug 29, 2003 | 09:49 PM
383ss's Avatar
thanks
