need help with t56 reverse problem
Old Aug 12, 2008 | 01:48 AM
wildn347's Avatar
Default need help with t56 reverse problem
when i put it in reverse it will go for about 3 secs then pop out of gear i tried holding it into gear but still popped out can anyone tell me what my problem is thanks
Old Aug 12, 2008 | 08:49 AM
calhoon's Avatar
You have a damaged shift fork or worn clutch teeth. This is generally the result of missing a shift and crashing reverse( several times). The cure is a teardown and replacement of linkage, synchrinizer and gear components at the rear of the transmission.
Old Aug 12, 2008 | 05:08 PM
thesource's Avatar
I'm gonna say its the reverse shift fork . Turn the car off , out it into reverse with some force (like you would power shift it racing) . Start the car back up and see if it does it still . If so , you are not getting enough throw from the shifter to the reverse slider . Most of the time its the shift fork and or shift fork pads only if you are lucky .
Old Aug 12, 2008 | 06:28 PM
wildn347's Avatar
can any of this be replaced with trans still in the car
Old Aug 13, 2008 | 09:40 AM
thesource's Avatar
Its possible but kind of a pain in the butt to do .
