3rd & 4th gear
Old Aug 12, 2008 | 02:23 PM
Speedin' Sam's Avatar
Default 3rd & 4th gear
I am getting locked out of 3 & 4th gear under hard shifts. Is this a sychro problem?
Old Aug 12, 2008 | 04:55 PM
thesource's Avatar
Probably broken 3-4 shift keys . Without them , the sycro rings slow down at a much slower rate which will be a lot more noticable at high rpm shifts .
Old Aug 12, 2008 | 06:29 PM
It works fine on normal shifts, it's the hard drag racing shifts that locks you out. It is supposed to have steel 3-4 fork and bronze fork pads. Could it be the throw-out bearing not holding at higher shifts (6K)?
Old Aug 13, 2008 | 09:32 AM
thesource's Avatar
Yeah the broken keys will make it harder to shift at higher rpms or in drag racing situations . The keys are not there to keep the syncros from completely spinning around and makes its harder for them to slow down .
