problem with 6th
Old Aug 22, 2008 | 03:48 PM
duece_bigalo01's Avatar
Default problem with 6th
Hey everyone I'm hopin you guys can help me on this but I have an 01 SS M6 that has a problem with 6th gear. This trans will pop out of gear in 6th and thats the only gear it does it in. All the other gears are fine. The trans will go in the gear just fine and if I hold it in gear then it stays. its got no funny sounds or anything else other then it wont stay in 6th gear.
Old Aug 22, 2008 | 05:15 PM
85MikeTPI's Avatar
As long as you don't have any shifter stops mis-adjusted, most likely your shift fork pads are broken. The syncho keys may be damaged as well. Either way, if it's not the shifter, it's time for a refresh.
