Pilot bearing questions
you get a bolt with threads slightly larger than the opening of the bushing. the bolt has to be longer than the depth of the bushing.screw the bolt through the center of the bushing, when the bolt bottoms out on the back of the crank, you keep screwing the bolt in and it will force the bushing out. ive used this method several times and it really works!
