McCleod Clutch Master Cyl
Old Sep 2, 2003 | 09:58 PM
SSEUL8R's Avatar
Default McCleod Clutch Master Cyl
Will putting this on my 98 M6 help me get the clutch disengaged faster and more completely disengaged? I have a centerforce on it now and some people said a McCleod master will help it disengage faster. Is this the case?
Old Sep 2, 2003 | 11:34 PM
felton316's Avatar
Default Re: McCleod Clutch Master Cyl
I believe it has a larger diameter bore. So technicly it should move more fluid, when you apply the clutch. Have you done the drill mod to the hydrolic line yet? The stock line has a restriction in it that slow fluid movement down.
Old Sep 3, 2003 | 03:25 AM
smokin' joe 00 ss's Avatar
Yes it helped mine out alot along with the drill mod.
