Grinding into 4th????
I replaced my tranny, clutch, throwout bearing, pilot bearing and resurfaced my flywheel. Everything is running great......well it was.
This morning driving to work I let the RPM's get over 3K before shifting into 4th and when I did it grinded really bad. That is the only gear it does it in and it will only do it if I shift fast or shift high in the powerband.
I rebuilt the Tranny with a Tick Performance stage 2 kit. The clutch does engage right off the floor also.
Any help would be appreciated guys.
Second question, will an adjustable MC take care of the problem??? I have a brand new GM one I did the drill mod on, so I will just make it adjustable.
bleed the clutch line and i would take the master and tip it up and push in the master cylinder and have someone look if you have bubbles come out the resivour. but since that is such a pain in the a$$ it might be worth buying ADJUSTABLE master cylinder. that is what i did. i bought the mcCloyd adjustable master and when i took the old one out i had a bunch of bubbles come out of the cylinder up to the resivour that was causing my peddle engagement to be on the floor and it sucked!!!!
putting a new adjustable master in there should solve this problem and take care of anything down the road. its so nice being able to adjust that to where I want it i love it. moved it twice already since i put it in this spring
So before I tear out my brand new MC and make it adjustable, is this what is causing it or could it be something else?
from what i have heard about is either the adjustable master or maybe the syncro is going bad and the tranny needs a overhaul. the clutch line should be hooked up the whole time. the master will not compress with the line off.
it may just save the headache it causes lol.if the resivor got dry at all during clutch install and such the master probably got air-locked. i went thru it as well. was gonna go thru the work of taking it out and bleeding it but it can be a hassle and i was not sure at all so i bought an adjustable. during removal i tipped it up to get it out and got a bunch of bubbles out of it
