Lou's Short Stick
Re: Lou's Short Stick
I was told that the major advantage of a true "short throw shifter" (not just stick) was to change the pivot point under the base of the stick. Neither LSS or JSS would do that because they only change the stick. Is this true? As far as changing the working part, any opinions on which would be best: B&M, SLP, Pro 5.0? Maybe the best solution is to use both the LSS or JSS with another shifter. Also, anyone try this stick? http://www.austinperformanceinc.com/qstik.html
