clutch issues!
Old Oct 4, 2008 | 08:50 PM
Captain_Stabbin's Avatar
Default clutch issues!
i am havin sum unknown problem with clutch, i just replaced slave an master clutch is not releasing it only realeases if i bump tha car over in gear an it kinda rocks back an fourth like its hangin up or sumthin not sure but once you do that a couple of times it seems to work fine till you turn car off then it happens all over again its a 99z m6 with 50,000 miles completely stock except for spec 3 clutch
Old Oct 4, 2008 | 10:24 PM
Default slave
another thing it seems like it's doin.. it seems as if tha throw out is gettin stuck in between tha fingers on tha pressure plate my question would be do you have to have aftermarket slave , if you have aftermarket clutch
Old Oct 5, 2008 | 03:31 AM
dre2013's Avatar
i had a similar problem...ended up being my throwout bearing
Old Oct 5, 2008 | 03:45 AM
yea but i just put a new slave/throwout bearing in it
