Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Can anyone help with nitrous?
Old Mar 18, 2009 | 08:33 PM
Ethan[ws6]'s Avatar
I know I need a heater. I know I need alot of stuff that kit won't come with. But I thought that all a heater did was heat up the Nitrous oxide so that it would expand inside the bottle to create more consistency, and very little pressure lose.
Old Mar 18, 2009 | 08:45 PM
JUICED96Z's Avatar
A heater cranks the pressure up but you have to watch it or you will get to much pressure and have to purge ir a bunch. Past like the 1/8th mile you will see a preasure drop even with the heater on. This is why people or going with a NANO. Its expensive but you can get every last drop out of the bottle and its keeps the pressure perfect the entire run. Not really needed though for the smaller shots but thats just my opinion.
With just the bottle you may only be able to use like 6 pounds before you have to refill, with a heater like 8, with a NANO all 10 pounds in a 10 pound bottle.
There are guys with a 300 ish shot that have picked up .3 with a NANO but again they are not cheap. With what you want, get a heater haha.
P.S. I will never ever run a progressive.......... ever.......... to hard on the noids.
Old Mar 18, 2009 | 08:54 PM
Ethan[ws6]'s Avatar
Yeah and I planned on getting one of those switches as well. I don't really want my car to be fucked just because I miss a gear lmao.
Old Mar 18, 2009 | 09:04 PM
JUICED96Z's Avatar
Get some TR-6 plugs.... theya re not that great N/A but you will need then for the bottle.
I think there is a company on here that will give you the plugs for free if you buy the MSD wires.
Old Mar 18, 2009 | 09:07 PM
Ethan[ws6]'s Avatar
What's the difference on the plugs? more spark?
Old Mar 18, 2009 | 09:14 PM
JUICED96Z's Avatar
Colder.
The more power you make the colder the plug you need. Not really more of a spark as it is hoter of a spark.
To give you an idea a -6 is a good bolt-on with bollte plug. A -8 tends to be about right for a built motor (not talking good daily driver) on the motor with some juice, -10 is built motor on a 300 shot or so.
I got some -8's for my last car, and they were like $3 a peice and they don't last forever.
When it comes to plugs and spraying keep an eye on the plugs and replace them fairly often.
The 300+ shot guys check the plugs every run and most replace them every run or every other run.
Old Mar 18, 2009 | 10:17 PM
Ethan[ws6]'s Avatar
I see. I'll have to check into it.
Old Mar 20, 2009 | 01:10 AM
birdmaro's Avatar
you are probably better off making your own kit.
nos solenoids are known to stick...
but their high flow bottle valves have worked wonders for me
zex makes good heaters.
lines are lines
TNT makes reliable window switches (or used to idk i haven't gotten new no2 stuff in quite a while)
look around, do your research etc. installation is easy. bring a laptop to your car, sign onto aim, and i can walk you through it via IM...as i'm sure many of the guys on this site can do.
Old Mar 20, 2009 | 01:20 AM
b00sted's Avatar
Originally Posted by JUICED96Z
Whats your point?
Do you know how many runs a 10 or 15 pounder will get you with no heater or NANO?
I got 4 solid passes out of a 10 pounder and 7 out of a 15 pounder with no heat...With a 150 shot.
Old Mar 20, 2009 | 01:24 AM
b00sted's Avatar
Its more of a saftey thing for you and others. I have seen what O2 tanks (20 pounders) witll do when they blow at 1,000 psi..... at the very least the back of your car will be shot, if you mount the bottle up front..........
What?
When a burst disc lets loose it makes ALOT of noise and vents ALOT of nitrous quickly. All the tube does it direct it out of the cabin so you don't get burned or asphyxiate.
Old Mar 20, 2009 | 02:09 AM
spray_goat's Avatar
hey ethan when u get ur kit hit me up, bring it over and we'll get it in and workin
Old Mar 20, 2009 | 07:45 AM
  #32
Ethan[ws6]'s Avatar
Sweet. James talked me into a wet kit so I'm going to see if I can get one cheap. I priced a 150hp wet kit with a heater for like 700 dollars but I'm going to see if I can find it cheaper anywhere else. No point in spending extra money for nothing haha.
Old Mar 20, 2009 | 09:02 AM
  #33
ws98ta's Avatar
You can put a used set together for cheap.
I have just over $500 in mine and got almost everything here used.
I have a wet kit with timing tuner/window switch, Fpss, blow down, 15# bottle w/ pressure gauge, nitrous filter, heater, and purge. I have the NOS powershot noids good to 200hp. So not the biggest noids but I'm not going to spray 300.
You can find good deal if you check the classifieds.
If you want I'm in greenwood aswell. You can come check my kit out and I am also willing to help with you install.
Old Mar 20, 2009 | 10:07 AM
  #34
JUICED96Z's Avatar
Yep, and I have seen guys get about 7 or so out of a 10 pounder on a 150 with heat.
What?
Agreed, I would not want to risk a massive fire and bottles have been known to explode....... Id never trust that little burst disk. I should have worded my post better.
Tube gets the nitrous out of the car but bottles can and do sometimes explode.... its rare and often because someone uses a torch but its happens.
Buying everything used is fine but don't trust the noids. Pull them apart and rebuild them and use the teflon parts. If the N20 noid sticks open then you might as well yank the engine. I got an NX wet kit on here used with 20 passes shipped for like $400 years ago. Stay away from the dry shots. Yes they can be made to work but you need a fuel system most of the time.
I know on the LS1 and LT1 cars a 150 shot is safe all day long if you have the plugs and an aftermarket fuel pump like the racetronics. I would not spray anything with a stock fuel pump but thats just me.
Old Mar 20, 2009 | 10:12 AM
  #35
Captain InsaneO's Avatar
I only got 4 solid passes with a 10lbs. bottle WITH heat. After that it was hit and miss. I also sprayed a 150 shot many times when I had a sock fuel pump with no issues.
Old Mar 20, 2009 | 10:42 AM
  #36
JUICED96Z's Avatar
Thats odd....
Never said it can't be done with the stock fuel pump. Just safer.
An aftermarket pump is cheap insurance. Granted they can go also.
At the very least get a fuel pressure switch if you want to stay on the stock pump for a while.
Old Mar 21, 2009 | 01:14 PM
  #37
Ethan[ws6]'s Avatar
Yeah I wouldn't mind looking at your setup sometime. Do you cruise in greenwood often?
