Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Failed Emission Need Help
Old Jul 23, 2009 | 05:35 PM
JacobK's Avatar
Default Failed Emission Need Help
Well i go to the emissions place in bedford park today, no SES codes or anything thrown at all..figure it will be fine..so then the guy tells me to go to the office, and hes talking all the **** that i dont understand, but from the sheet i have, there are no DTC codes being thrown but under the part that system monitors there are 3 things that say, "Not Ready" and those are catalytic converter eff, evaporative control system, and heated oxygen sensor...So does anyone know what the hell i can do to fix this so i can get my tag on my car since its expired...The car doesnt have cats or anything, and i REALLY REALLY dont wanna put them back on if thats what its trying to tell me...Also where did u guys go to get your car tested...Thanks!
Old Jul 23, 2009 | 05:51 PM
02TransAm/Batmobile's Avatar
I've been to the same place. Maybe he's hating on your ride.
Old Jul 23, 2009 | 06:31 PM
CHIWS6's Avatar
u have to drive the car more the systems can ready up. i had the same situation what i did was drive the car around so they can ready up and i went the following day to retest, then i pass
Old Jul 23, 2009 | 09:45 PM
TransAmy's Avatar
im almost positive those systems on my sheet also said not ready, but i passed in crystal lake. just got tested a few weeks ago.
Old Jul 23, 2009 | 10:43 PM
b00sted's Avatar
His not ready tests are due to vehicle mods...Not because it hasn't completed the tests yet.
Old Jul 23, 2009 | 10:46 PM
b00sted's Avatar
Also, I go to the markham testing place. The employees there aren't 'motivated'.
I went through with open exhaust, a huge cam, and it was untuned reeking of raw fuel. As it was on the OBD tester, the employee walked around back and waved in front of his nose making the "This car stinks" face to me.
Old Jul 23, 2009 | 11:06 PM
98blueSScamaro's Avatar
true you have a hater on your hands only 5 or 6 system have to say ready or passed with no check ses light on but if they know your ride dirty then go to another test place
Old Jul 23, 2009 | 11:21 PM
ski23's Avatar
Jake, Mine did the same thing when I put the headers on. Had Outlaw tune codes out but, He fucked up the tune and set them to off instead of on and no reporting. I had a local fix the issue for me. Had to drive the car for it to report.
I Did a search on here and found info on GM driving cycle. It goes thru what you have to do to force computer to run the cycles. Had to do something like drive at 55mph in 6th gear for 3 miles, let off gas and cost down to 40 while in gear, then climb to 60 etc.... Look into it. If I find it ill link you
Old Jul 23, 2009 | 11:39 PM
02sleeperz28's Avatar
Either you have a hater or you need to drive your car more. Same thing happen to me because my car was sitting up for awhile though. I go to the same place in Bedford Park, they told me to bring it back in a couple of days after driving it for awhile and I passed.
Good luck!
Old Jul 24, 2009 | 11:53 AM
MadIceV8's Avatar
Customizing Director
Sounds like you have the monitors to off, which will not let you pass. You need to have the monitors set differently. A tuner that has an idea of what he's doing will be able to fix that.
Old Jul 25, 2009 | 08:13 AM
jcws6's Avatar
Here's a little tip I found:
If you KNOW your car will pass the emissions part (tailpipe exhaust, etc.), you can clear your computer with a handheld OBDII tester right before you pull into the place (hide the tester in your glovebox or something). Most of the time, the PCM itself will return "Not Ready," which will force the tester to run a tailpipe test.
Not sure how they do it in Illinois, but this worked with my Blazer in Ohio. Worth a shot, if you have an OBDII tester that can clear codes.
Old Jul 25, 2009 | 10:19 AM
partyhardoo69's Avatar
haha i tried that once.
the guy showed me the sheet and told me i was 5x over the legal limit. I reset my battery and went for a quick drive. Went back in the same guys lane and he hooked it up to the scanner. I passed and went on my way.
Old Jul 25, 2009 | 11:13 AM
b00sted's Avatar
You're only allowed 1 Not Ready. I think 98s and older are allowed 2.
He currently has 3...So they won't pass him no matter what.
You guys talking about drive cycles and tail pipe tests are pissing into the wind. It takes 10 minutes to 'fix' with the laptop.
Old Jul 25, 2009 | 02:32 PM
TORCHD 02 TA's Avatar
Jake those three things say not ready on my sheet to. I passed... There is an emissions place by my house on 53 and fullerton.. I think the town is Addison
Old Jul 25, 2009 | 02:48 PM
b00sted's Avatar
Maybe your confusing a few of the readiness tests that come up as "NOT SUPPORTED" with our cars.
Unless the laws are drastically different out there for some reason, you didn't pass with 3 "NOT READY"s.
Old Jul 27, 2009 | 08:24 PM
TransAmy's Avatar
glad to see youre not dead
Old Jul 27, 2009 | 08:36 PM
Wow i was thinking the same thing.. How have you been? PM me, what have you been up to?
Old Jul 31, 2009 | 04:34 PM
b00sted's Avatar
Ever get it taken care of?
Old Jul 31, 2009 | 06:43 PM
Hey Jake here is my Vehicle Inspection Report from the Emissions place
Comprensive Component - READY
Engine Misfire - READY
Catalytic Converter Eff. - READY
Evaporative Control System - READY
Heated Oxygen Sensor - NOT READY
Secondary Air System - READY
Fuel System Performance - READY
A/C Refrigerant - NOT SUPPORTED
EGR Flow - NOT SUPPORTED
Heated Catalyst - NOT SUPPORTED
Oxygen Sensor - READY
Stored Diagnostic Trouble Codes: NONE
Old Jul 31, 2009 | 08:10 PM
b00sted's Avatar
NOT SUPPORTED's don't matter. But you're only allowed one NOT READY on 99+ cars...Which is why he failed the first time around. I had the same issue the first time.
