Exhaust (minor fab) work near Indianapolis?
I am assuming this would be relatively easy for an exhaust shop.
If you look at the pics you can probably immediately see what I want done.
You can see that on the left side, all is well, with the exhaust coming straight out the back. On the right side, though, the exhaust comes out at an angle, first going up, and then coming down. As a result of this, the tip points down, rather than straight back. It doesn’t look good at all. I can’t see a reason for the part being bent like this (other than the initial one from the weld point), since there is nothing obstructing a straight path back. It could have looked identical to the left side and been perfectly fine.
I also want the tips welded on. Those little screw clamps aren't going to cut it.
What kind of price range would I be looking at?
All leads are much appreciated.
Thanks
Ed
Thanks
Ed
