Broke off corner of block. Help!
What are the actual specs on that cam?
An aluminum block would just get welded up and a new hole machined in.
Spray welding is supposedly the strongest way to fix a cast block.
I have not done it yet, like I said, I drilled it deeper and repaired it myself.
I will be getting it done when it comes apart for the winter.
Mine is a brand new Big M, that I have almost $3000 in, that there's no way I can just scrap because the corner is gone.
Even if I have to spend a few hundred bucks, I'm doing it.
If I can find my notes, I'll post who does it in the Chicago area.
Secret stash hidden in your tool box. When you saved up enough, she'll never know what you do??
My crew chief does side jobs all the time and hides the money for himself.
