Back in MW
1 Post
I am moving to Illinois...near Scott AFB. My car/mods are listed below.
02 SS
408 from HKE Racing
TFS 235 heads
Yella Terra 1.7 rockers
10% Powerbond pulley
FAST 92 / NW 92 Vengeance ported
85mm Z06 MAF
cam 242/244 610/612 113+3 degreed by HKE, Yella Terra 1.7 rockers
Kooks 1 7/8 headers with ORY (magnaflow catback) Dual DMH cutouts
Moser Rear end 12 bolt with 3.42 gears and TruTrac from EPP
Performa built level II transmission with Yank 3600 stall
Bore and Hone W/ TQ Plates up to .030 over
Line Hone Main Bores
Set Deck W/ Customer's Pistons
Balance Rotating Assembly
Assemble Engine Short Block
Core 6.0 LS1 Block
Eagle 4340 LS1 4.000 Crankshaft
Callies Compstar 6.125 LS1 Rods W/ ARP 2000 rod bolts
Wiseco K445H3 LS1 15cc Pistons 4.030 Bore
1/16,1/16, 3.0mm Rings 1.110 Comp. Height
Wiseco HF Piston Rings 1/16, 1/16, 3.0mm
Federal Mogul 152M 3/4 Groove Main Bearings for LS1
ACL CB 663 H Rod Bearings for 2.100 SBC Chamfered Race Bearings
Durabond CH 10 LS1 Cam Bearings uncoated
ARP 234-5608 Main Studs for LS1
Rollmaster LS1 adjustable Double Roller Timing Chain
racetronix fuel pump, 42#injectors ford racing
LS6 ported oil pump
LS6 valley conversion; catch can; UMI torque arm with driveshaft safety loop, panhard bar, this is all I can think of for now.
I will post up the results when it is done. Motor will be here in a week or so. I have to deploy soon and may not be able to put the car together before I am gone.
Car made 500/472 on the dyno lower line is from old AFR 205 heads (small bore)
02 SS
408 from HKE Racing
TFS 235 heads
85mm Z06 MAF
Core 6.0 LS1 Block
LS6 ported oil pump
