Any oklahoma guys looking for a motor and exhaust??
I have a ls1 aluminum motor with trick flow heads and cam for sale. also have full slp exhaust for sale. headers to tips.
MOTOR WAS PULLED FROM A 2000 CAMARO SS TO MAKE ROOM FOR A 408 STROKER. MOTOR WAS PULLED JUST THIS PASSED WEEK WITH ONLY 78000 MILES. MOTOR HAS NO FLUID LEAKS AND RAN GREAT WHILE IN MY CAR. I JUST WANTED MORE POWER. MOTOR PUT DOWN OVER 415RWHP IN 98 DEGREE TEMPS. MOTOR HAS NEVER BEEN SPRAYED, NEVER BEEN TO THE TRACK, NEVER HAD ANY POWER ADDERS. CAR WAS IN HOTROD POWER TOUR AND I HAD NO PROBLEMS WITH HOW IT RAN AND NEVER OVER HEATED..........ALSO OFFERING AS A PACKAGE DEAL IS A FULL SLP LOUDMOUTH II EXHAUST. EXHAUST WAS PUT ON THE CAR A YEAR AND A HALF AGO AND ONLY HAS 11000 MILES ON IT. HEADERS ARE 1 3/4 AND EXHAUST IS ALL 3INCH WITH 3.5 INCH SLASH TIPS. YOU WILL GET ALL HARDWARE BUT EXHAUST FLANGE BOLTS. $4100 OBO FOR THE MOTOR AND EXHAUST. $3300OBO FOR MOTOR ALONE. I AM NOT GOING TO PART OUT THE MOTOR PIECE BY PIECE SO DONT ASK. I WANT ALL OF THESE PARTS GONE!!!!! possible shipping out of state.. MOTOR IS IN NORMAN, OK.
Head and cam kit came with:
220 as cast tfs heads and valves WORK DONE BY TEA
titanium retainers
heads milled to 61cc
.650'' lift dual springs
heads will come complete with valves and rockers
stock rockers with comp cams trunion kit
comp cams high rev lifters
ktech ls6 style timing chain.
mellings high flow oil pump. has great oil pressure
front, rear, and head gaskets all new
vrx4 cam shaft and trick flow 7.4 pushrods
ls2 intake
bbk ls1/ls2/ls3 fuel rails
new pilot bearing
all internal motor parts were properly put together and prelubed with royal purple prelube
all bolts on motor were properly torqued to spec.
motor has new gm crank bolt
e3 spark plugs
plug wires
Motor will not come with:
accessories
wiring harness
cam and crank sensor
coils and brackets
fuel injectors
titanium retainers
ls2 intake
new pilot bearing
e3 spark plugs
plug wires
accessories
wiring harness
coils and brackets
fuel injectors
