Where to get Spohn sway bar & relocation brackets welded in Chicago.
The Spohn sway bar needs to be welded by the end links, as stated on their website, and the controll arm relocation brackets need to be welded as well. What shops have you guys had this type of work done at with good results? I'm not opposed to driving a distance to get the job done right. Any opinions? thanks
Jimmy
Jimmy
Well, Speed Inc. is one of the sponsors on the board, might want to contact Larry. They are located in Schaumburg. Also, FLP (Finish Line Performance) is located in Naperville and they also do great work.
I have been to both Speed Inc and FLP. I am just trying to see what options are. I have heard of people braking stuff at the welds, so I want someone that has a lot of experience with welding to do it. Does Speed Inc and FLP do a lot of suspension welding? Bob, I have heard very good things about your shop. You are about 3.5 hours away from me. I will keep you in mind though.
