Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Illinois emissons?
Old Nov 21, 2005 | 07:08 PM
formula001's Avatar
Default Illinois emissons?
Does anybody no what the illinois law requires to pass emissons? I was looking to get some headers in the next month or so and was wondering if it would keep me from passing. Also I know this is in the wrong place but what about the biggest cam i can run in kane county illinois? Thanks.
Old Nov 21, 2005 | 07:42 PM
WhiteKnightZ28's Avatar
Tech Resident
This may not be of much help but, I'm a CT emissions tester, the way we test newer cars (OBD II, compatible 96 and up) is we simply plug into your onbord computer. as long as the check engine light isnt on you'll pass just fine... but thats here in CT... i would just call your local DMV... you may have to wait on the phone for hours but they should be able to answer your question.
Old Nov 21, 2005 | 07:44 PM
CNTLSE 1's Avatar
I'm from Charleston Illinois and have never done an emissions test in my life
Old Nov 21, 2005 | 07:49 PM
formula001's Avatar
I wish thats how it was where I am at.
Old Nov 21, 2005 | 08:08 PM
SmokingWS6's Avatar
I use to work at MO testing stations also. OBDII checks for readiness and codes only. If Illinois use's the obdII test, what mods will pass/won't pass are irrevlent since they can all be taken care of with pcm tuning.
Were in IL do you live? I'm a local tuner in St. Louis if you should need any help.
Old Nov 21, 2005 | 08:09 PM
formula001's Avatar
Any body else know what the laws are?
Old Nov 21, 2005 | 08:12 PM
SmokingWS6's Avatar
http://www.strangauto.com/emissions.htm
Looks like you won't have to worry about anything, mod away
Old Nov 21, 2005 | 08:25 PM
formula001's Avatar
Alright thanks for the help.
 Michael S. Palmer
Old Nov 21, 2005 | 09:09 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
IL is OBD scan only for '96 and up. No sniffer, no visual for '96+.
Old Nov 21, 2005 | 09:51 PM
yak's Avatar
yak
i have a bad feeling kane county has some really bad emmissions laws. I live in Kane county, (St. Charles) and have yet to take my car in. My parents told me that they had a sniffer when they brought in our 2000 minivan. this would really suck considering I am catless with a big *** cam.
Old Nov 21, 2005 | 10:07 PM
formula001's Avatar
Yeah im right down the road from you in elgin. Havent had my car there yet just wondering what is going to happen when i do.
Old Nov 21, 2005 | 10:08 PM
formula001's Avatar
When you go shoot me a PM and tell me how it went.
Old Nov 22, 2005 | 05:45 AM
RPM WS6's Avatar
There should not be any difference from county to county in IL for the type of emissions tests used. Last I heard there were 10 counties in IL that have testing, 7 around Chicago and 3 around St. Louis.
Odd that your 2000 minivan would have had a sniffer. A 2000 model year car would have tested for the first time in '04. My '00 WS6 was also due in '04 for it's first test, and there was absolutely no sniffer used on that car, OBD scan only. Are your parents positive a sniffer was used? If so, I have no idea why. Should be scan only for '96 and up.
Old Nov 22, 2005 | 07:46 AM
SgtB's Avatar
Mod, Mod, Mod....then get your car tuned and you will pass
I posted up a little while back when I passed..thanks to a couple of board members that got me all hooked up.
Old Nov 22, 2005 | 08:26 AM
BGImportkiller's Avatar
They only use sniffers on 96 and up cars if they fail the OBD test. The tuning will take care off it. Either that or get race car exemption, which is what I did because I have a 95.
Old Nov 22, 2005 | 12:48 PM
lt1maro's Avatar
how do you get a race car exemption because i just put non emmissons long tubes on my 95 and they will probably laugh at me if i try and get my car tested?
Old Nov 22, 2005 | 05:56 PM
RPM WS6's Avatar
That is no longer an option. The OBD scanning was phased into effect in 3 stages. Here are the details from the IL EPAs website:
Phase 1: from July to October 2002: 1996 and newer vehicles that pass a gas cap pressure test and an OBD test will pass the emissions test. An exhaust test will not be performed when the vehicle passes the OBD test. If the vehicle fails the OBD test, it will be given a second chance to pass by receiving an exhaust test. In this phase, vehicles that fail the emissions test can be repaired to pass either the OBD test or the exhaust test.
Phase 2: from October 2002 to January 2004: Owners of 1996 and newer vehicles will be able to decide whether to repair their vehicle if it fails an OBD test, or to be given a second-chance exhaust test. In this phase, vehicles that fail the emissions test can be repaired to pass either the OBD test or the exhaust test.
Phase 3: beginning January 1, 2004: The emissions test for most 1996 and newer vehicles will consist of a gas cap pressure test and an OBD test. In this phase, vehicles that fail the OBD test must be repaired to pass the OBD test.
After 1/1/04, no sniffer test would be given for cars failing the OBD scan. It does, however, state that "most" '96 and up cars will receive the OBD scan. I suppose that means that in theory, certain newer cars may still be receiving the sniffer, but personally I have not heard of a single '96+ car getting anything but the OBD scan since Jan. '04. Either way, when it comes to '96+ Camaro/Firebird, they all get OBD scan only tests at this time.
Old Nov 22, 2005 | 09:26 PM
wrencher's Avatar
wrencher
OBD -II cars all they want is to be able to pull the vin, & bin file on the PCM. Then the readness test status w/ no trouble code report. They also pull the generic hex out as well, it is all stored.
It is an emission test out of the hands of the inspector, their system does it all automatically.
Old Nov 25, 2005 | 11:15 PM
oohtwo WS6's Avatar
I can tell you what happened to me from experience. I went the last week of October 2005 to the test station off I-55 and Rt. 30 in Joliet in my 1997 Cavilier...it was pretty busy ...10 cars each lane 9:30 am on a tuesday....all lanes from what I seen were still running the dyno run with the sniffer....I waited 10 minutes and a guy comes out and opens another bay and flips open a sign that says " 96 or newer vehicles " so I drove in first and got the OBD test....all other lanes were running the dyno with sniffer on all cars.
Thursday that same week, I took my wifes 2001 Honda CrV to the test station off I-355 and Ogden in Downers Grove at 9:30 am and there is 2 lanes that say "96 or newer only" open, I pull in and get the OBD.
I think it depends where you go....nicer neighborhoods where nicer, newer cars may play a roll in the station having OBD lanes open at all times. Pull away if you dont see the 96 or newer sign......both times it was the far left lanes. I dont think they run them all the time everywhere.
Old Nov 26, 2005 | 12:00 AM
RPM WS6's Avatar
At the station I go to (in Skokie), the lanes are dual purpose. There is no "'96 or newer" sign that I've seen for any lanes (last time I was there was mid '04). I've gone and had pre '96 cars directly in front of me (same lane) take a sniffer, then I pull in and get an OBD test.
There is no reason why any '96 and newer cars should still be getting any sort of sniffer test in the state of IL. Obviously, you saw what you saw, but something is very wrong at that station if they are giving sniff tests to '96+ cars.
