Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Trans stuck in 3rd????
Old Mar 19, 2006 | 08:04 PM
SgtB's Avatar
Exclamation Trans stuck in 3rd????
https://ls1tech.com/forums/automatic-transmission/472472-trans-stuck-3rd.html
Old Mar 19, 2006 | 08:27 PM
Matt D's Avatar
Retired Street Racer
If you scan it, it will be throwing codes for the shift solenoids. Check your ENG CTRL fuse under the hood to make sure it is not blown.
Old Mar 19, 2006 | 08:37 PM
SgtB's Avatar
I checked both the 15A and the 50A.
Neither is blown...
I used my dad's scanner at his house. I do not have one at my house.
Old Mar 19, 2006 | 08:46 PM
Matt D's Avatar
hmmmm, did you have the pcm tweaked after the converter was put in?
Old Mar 19, 2006 | 08:47 PM
SgtB's Avatar
yup..i put the converter in last summer...it has been fine till today.
I just cant figure out why it stuck in third.
Old Mar 19, 2006 | 09:01 PM
SgtB's Avatar
weird.
especially since everything is new(less than 1K miles) I am stumped on this one.
Matt D's Avatar
I had the same problem, that's why I asked. It was an electrical short coming from the solenoids to the fuse box.
Old Mar 20, 2006 | 07:55 AM
SgtB's Avatar
So, I took the car for a ride this morning. It still has the SES light but the car is driving normal again. Most likely it is a tuning issue then?
Old Mar 20, 2006 | 11:18 AM
Matt D's Avatar
Yes, probably. Scan it and see what the code is for, and let me know.
