2001 SHORTBLOCK in SE MICHIGAN f/s
I have a 2001 engine shortblock that I need to get rid of. Had a valve drop and dented one of the pistons, didn't damage any of the liners though. Needs a good rebuild/machining ect..., but the whole block itself and internals are fine. I'm looking to just get rid of it. It will NOT come with any sensors, oilpan/windage tray, timing chain, cam ect... Its just your block, front/rear covers, pistons/rods, crank, plugs. It will not be torn down but sold as a complete unit and I will not seperate parts.
This will be a local pickup ONLY since i have no way of shipping it. I'm looking for 200 bucks picked up. Engine is located in Garden City, MI. Just down the street from Dearborn. Its also probably about 3 miles from Livernois motorsports if you want to take her there for the rebuild, they do good work.
Thanks!
Adrian
Thanks!
Adrian
Sorry fellas! You should have sent me a PM, as I said I don't mingle in the regional section. Already sold it this past monday. Ended up having a crack in the block that I didn't see before, so I ended up refunding 150 of the money. Not sure on the condition of the crank/rods, but I'm sure they're fine. You will ALWAYS have to replace bearings when rebuilding an engine.
Best Regards!
Adrian
Best Regards!
Adrian
