Anyone wanna Help With some projects
For the brake booster, Not sure what you'll need off the top of my head.
For the rack - You'll need Wrenches - 13MM, 15MM, and a 18" deep socket. You'll also need a way to raise up the motor to get the driver side bolt out of the rack so you can remove the rack itself. On the spindle mount, you'll need an allen to hold the center while you take off the nut. Other then that i think you're good to go, i think the actual lines for the power steering lines are 15's I could be wrong though. Brakes are all cake, they're 15MM's. You may need some wirecutters or something to remove the rotor retainor clips that arent atually needed in the first place as well. I think thats about everything I can thiink of.
