Final Speed Inc Caravan Thread
i threw....system lean/injector circuit open/multiple misefire. ended up just being my o2 sensors. i also have the slp maf and my car runs like crap at idle kinda rough and terrible gas mileage
yep, so what did you do to fix it...
I know I did have a loose spark plug wire!
If you can't lead the group will you still be going? I just need to know so we can still setup the smoke show at the begining. If you're still going you can still be the one to stay in contact with me even if you aren't leading the group.
I checked all the spark plugs under the hood and found that the passenger side 2nd cylinder from the back (cant remember the cylinder number), the spark plug wire was loose and not snapped on, so snapped the plug on. I could see this being the culprit. This would cause the misfire, which would lead to the chain of O2 codes.
the car idles good again, and the gas mileage went up... LOL beats the 120miles to a full tank I was getting...
with this being said I can still lead and will be at crystal lake hooters at 8:30
