Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
NMCA Race Late model EFI class.
Old Apr 30, 2007 | 10:23 PM
ls1 joe's Avatar
Default NMCA Race Late model EFI class.
There is a race this weekend in Bowling Green Ky. They have indexes from 9.50 to 15.00. Here is a list of what can race, and you can race the Open Comp if you don't fit in the EFI classes. I will be racing Open Comp. Come out and show your support.
Chevrolet Corvette , LS1, LS2, LS6, LS7, 1997-current
Chevrolet Camaro, Pontiac Firebird/TransAm LS1, 1998-current
Chevrolet SSR, LS2, 2005-2006
Chevrolet Trail Blazer, LS2, 2006-current
I am sure that 04 to 06 Pontiac GTOs can run also.
Old Apr 30, 2007 | 11:56 PM
Matt D's Avatar
Retired Street Racer
Good luck. A buddy of mine is running Xtreme Street with his BBC Camaro. My car won't be ready in time, but it will be for the race at Route 66 in July. I will be running the EFI class on a 11.50 index.
Old May 1, 2007 | 12:01 PM
ls1 joe's Avatar
Hope to see you there, we need to get as many people as possible to race.
Old May 1, 2007 | 06:43 PM
Wicked ls 1's Avatar
Is this anything goes index or is there special rules, As in mufflers,dot tires. Otherwise Ill make RT66 for the 11.50 class as well.
Old May 1, 2007 | 07:07 PM
ls1 joe's Avatar
There are rules like no sheet metal intakes but I think any tire, muffler and has to be street legal. Mines is not street legal so I have to run open comp
Amber
Old May 1, 2007 | 08:11 PM
Matt D's Avatar
Only rule is no electronics, (delay box, throttle stop, etc). I would love to run a throttle stop but I guess it is unfair
Old May 2, 2007 | 05:08 PM
What about trans brakes,me no like trans brakes makes us footbrakers look bad.
Old May 2, 2007 | 07:51 PM
Matt D's Avatar
It doesn't say anything about trans brakes...
Class Guidelines
2.12 MANUAL TRANSMISSIONS
MANUAL TRANSMISSION: OEM or aftermarket transmissions with a maximum of 6 forward speeds permitted. Clutchless transmissions prohibited.All shifts must be made manually without the aid of electric, hydraulic or pneumatic devices. Starting line rev limiters permitted. Torque converter not permitted with this type transmission.
2.13 PURPOSE BUILT TRANSMISSIONS
PURPOSE BUILT TRANSMISSIONS: Prohibited.
2.14 AUTOMATIC TRANSMISSIONS
(OEM American transmissions or replicas of OEM American transmissions that use planetary gears) AUTOMATIC TRANSMISSIONS: Automatic transmissions originally produced by any American automobile manufacturer or replicas of an automatic transmission produced by any American automobile manufacture (Ex. Deadenbear PG transmission) are accepted.
9: SUPPORT GROUPS
Bracket racing aids such as optical sensors, delay boxes, stutter boxes, and throttle stops prohibited. The application or use of any device, mechanical or electronic, that permits the driver to ascertain the position of their vehicle in relation to the starting line is prohibited.
9.2 ONBOARD DIAGNOSTICS/DATA RECORDERS
ONBOARD DIAGNOSTICS/DATA RECORDERS: Onboard diagnostics and data recorders used to monitor and record parameters such as a driveshaft speed, acceleration, nitrous timing, chassis strain, suspension travel etc., accepted. Wide band oxygen sensors permitted. “Playback” tachometers permitted. Laptops permitted in vehicle.
ls1 joe's Avatar
You can find the full rules on NMCAracing.com
Old May 4, 2007 | 06:09 PM
ls1 joe's Avatar
Bump for the day
Old May 4, 2007 | 10:45 PM
LS1BADZ's Avatar
Yet 15 and the hit was "unfair"???
Old May 8, 2007 | 12:57 PM
Matt D's Avatar
Put it on a tire, spray it, and I'll keep mine on motor. We can run heads up at SCC. Otherwise shut the **** up, this thread is for people who ACTUALLY race competitively, not just test and tune and pick on 15 second cars.
Old May 8, 2007 | 12:58 PM
Matt D's Avatar
Here is the info for the series:
http://www.fasteststreetcar.com
