Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Route 66 tomorrow...
Old Jun 26, 2007 | 11:07 AM
Matt D's Avatar
Retired Street Racer
Oh, I thought you meant 11.50 and faster. My bad.
Helmet, driveshaft loop, metal valve stems on the drive tires, and your wheel studs have to stick out throught the lug nut the same length as the diameter of the lug nut. (If you are using slicks)
Old Jun 26, 2007 | 11:17 AM
BADSZ28's Avatar
... metal valve stems on the drive tires, and your wheel studs have to stick out throught the lug nut the same length as the diameter of the lug nut. (If you are using slicks)
Thanks again. I never would have thought of any of this.
Old Jun 26, 2007 | 11:34 AM
Matt D's Avatar
66 is a bunch of *****
Old Jun 26, 2007 | 11:49 AM
ONEBADWS6's Avatar
Have fun in 3000+ DA
Old Jun 26, 2007 | 12:12 PM
Matt D's Avatar
That's why I am going. So I know what my car will E.T. for NMCA next month when it is just as hot
Old Jun 26, 2007 | 02:01 PM
ONEBADWS6's Avatar
Don't forget your aqua treads.
Old Jun 26, 2007 | 02:04 PM
SpaZMaN's Avatar
havent gone outside yet, wonder if its still 150% humidity out...lol
Old Jun 26, 2007 | 02:44 PM
Matt D's Avatar
I just called and they are still running. The storm already passed through and the DA is +1929 (same year Bill was born )
Old Jun 26, 2007 | 02:50 PM
BADSZ28's Avatar
What is 66s elevation? I must be calculating DA wrong. I have calculated 2000DA in slightly cooler and less humid air. What is a good calculator to use?
Old Jun 26, 2007 | 02:53 PM
Matt D's Avatar
+635 feet
Air Temp: 75*
Humidity: 81%
Baro: 30.12
http://wahiduddin.net/calc/calc_da_rh.htm
Old Jun 26, 2007 | 02:55 PM
BADSZ28's Avatar
It's only 75*? OK. my calcs are on then. That is the same calculator I use.
Old Jun 26, 2007 | 02:58 PM
  #32
BADSZ28's Avatar
I get 1897.
Old Jun 26, 2007 | 03:00 PM
  #33
Cogs's Avatar
I might go and not run my car. Last week I ruined it for everyone at the end of the night after my car broke.
Old Jun 26, 2007 | 03:04 PM
  #34
02sleeperz28's Avatar
We will be there...
Old Jun 26, 2007 | 08:41 PM
  #35
Rare99Z's Avatar
Who's going? I will be there with my car trying to dial it in.
Rich? Cogs? Sean?
Post up if you're going
I was plannin on going til it started raining a little bit on my way home from work. Didn't feel like paying $15 if it was gonna be a rainout. Went last tuesday and was quite disapointed in my e.t. I need a stall bad. Instead I decided to put my new wheels on. Just got a set of Y2K's
Old Jun 26, 2007 | 09:46 PM
  #36
xpndbl3's Avatar
y2k....race car
Old Jun 26, 2007 | 10:02 PM
  #37
Rare99Z's Avatar
Originally Posted by xpndbl3
y2k....race car
pssshhhhhh pro stars, 4 inch cowl, carb........I think that qualifies for a race car, my car is just junk
Old Jun 26, 2007 | 10:08 PM
  #38
Matt D's Avatar
I went, had fun. The car is still the same. The DA was ranging from +1890-2000 all night long. Raceweight was 3325. Here were my runs:
12.071 @ 110.70 (1.62)
12.098 @ 110.37 (1.61)
12.098 @ 110.16 (1.62)
12.083 @ 110.63 (1.63)
12.093 @ 110.32 (1.62)
12.085 @ 110.45 (1.61)
12.069 @ 110.59 (1.60)
12.089 @ 110.68 (1.63)
Old Jun 26, 2007 | 10:56 PM
  #39
Matt D's Avatar
Here are some videos:
http://video.ls1tech.com/video/83106...59018a487d.htm
http://video.ls1tech.com/video/d85ec...5901899688.htm
http://video.ls1tech.com/video/4a56b...59018afd5c.htm
Old Jun 26, 2007 | 11:08 PM
  #40
01RedZ28's Avatar
Nice car looks good.. How did you manage to get so many runs in was it not busy there.
