Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Route 66 tomorrow...
Old Jun 26, 2007 | 11:16 PM
  #41
Matt D's Avatar
Retired Street Racer
No, it wasn't busy. The rain kept a lot of people away just like I hoped.
Old Jun 26, 2007 | 11:53 PM
  #42
xpndbl3's Avatar
so is that daylighting the front tires?
Old Jun 27, 2007 | 12:08 AM
  #43
88monte's Avatar
liqour enthusiest
its a street car, just looks like it. its not a trailer queen like your car
Old Jun 27, 2007 | 12:34 AM
  #44
SMOKY's Avatar
Tenured Member
Time to stiffin the rear suspension up a little and add some wheel limiters to the front. That should plant the tires harder and give a better reaction time. Just a though though.
Old Jun 27, 2007 | 07:18 AM
  #45
FLT's Avatar
FLT
Looks like it runs pretty consistant.
Old Jun 27, 2007 | 07:25 AM
  #46
Matt D's Avatar
Thanks to my FLT trans
Old Jun 27, 2007 | 07:27 AM
  #47
Matt D's Avatar
Yeah I have to mess with the rear shocks a little. They are the Comp 3-way adjustable set on 50/50, and I have the QA1 "R"s in the front set on fully soft. Pinion angle is -3* and tire pressure is 17* hot.
Old Jun 27, 2007 | 09:00 AM
  #48
BADSZ28's Avatar
I would not change a thing. Very consistant.
Old Jun 27, 2007 | 09:09 AM
  #49
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If you are not spinning, you might eke out a bit more by playing with the suspension, but you also might need more power or converter to 60ft harder, what converter are you running now?
Old Jun 27, 2007 | 10:45 AM
  #50
Matt D's Avatar
No it isn't spinning at all. My previous best 60ft was 1.57 at U.S. 41 in a little better DA. I have a Yank PT4400 converter in a FLT Stage 4 4l60e and a 3.42 gear in the 10 bolt. I need an underdrive pulley, a bigger gear (either 3.90 or 4.10) and more weight taken out. I will be going to a 28x9 ET Drag with the bigger gear and replacing the front radials with an ET Front for NMCA contingency. Here is my full mod list which can be seen on my FQuick page:
Performance:
Stainless 1 3/4-inch longtube headers
Magnaflow mufflers dumped off of the collectors
Direct-Flo air lid
LS6 intake
PTB ported throttle body
Custom ram air intake
160* thermostat
Taylor Spiro-Pro 8mm plug wires
15x4 Centerline Convo Pros w/ Kumho 165R15 radials
15x7.5 Centerline Convo Pros w/ 275/50/15 Mickey Thompson ET Street radials
Suspension/Chassis:
UMI subframe connectors
UMI chrome moly torque arm
Spohn lower control arm relocation brackets
Spohn chrome moly lower control arms
Spohn chrome moly panhard rod
Spohn chrome moly 1" rear sway bar
QA1 "R" front drag shocks w/ 275lb springs
Competition Engineering rear drag shocks w/ stock, cut springs
Airlift passenger side drag bag
Lakewood driveshaft safety loop
Drivetrain:
Stage 4 FLT 4l60e transmission
Yank Pro Thruster 4400 stall torque converter
LS2 flexplate
B&M transmission cooler
GM 3.42 gears
TA rear end girdle
Electronics:
Dyno tuned with HP Tuners by Straightline Performance
Aeroforce OBD2 Scan Guage
Old Jun 27, 2007 | 03:33 PM
  #51
Rare99Z's Avatar
You suck Matt. I've got almost all the same **** as you except the trans and converter and I'm a full second slower
Old Jun 27, 2007 | 03:54 PM
  #52
Matt D's Avatar
My car should be faster. It is off by about a half second. Two tenths are from DA, but the other three I don't know.
Old Jun 27, 2007 | 04:02 PM
  #53
BADSZ28's Avatar
Have you looked at the tune at all?
Old Jun 27, 2007 | 05:04 PM
  #54
Matt D's Avatar
Yeah, it has been dyno tuned by Straightline Performance.
Old Jun 28, 2007 | 10:37 AM
  #55
BADSZ28's Avatar
Hmmm...Mike does good work. Not sure what the deal is. Where is the verter flashing at?
Old Jun 28, 2007 | 01:34 PM
  #56
Matt D's Avatar
About 4800 or so. It is kinda hard to see when launching the car at the track. I haven't dynoed it since I replaced the TCI converter for the Yank.
