need torque specs for bellhousing/trans
Hey guys i did a search and checked install university with no luck. also posted this in manual trans section. anyone know the torque specs for the bellhousing and the trans? got my ls7/ls2 kit in and ready to button the trans up but, wanna make sure everything is torqued to spec. thanks guys
Transmission to bellhousing bolts 26 Ft-lbs
Back up light switch 28 Ft-lbs
Reverse lockout housing hold down screw 156 in-lbs
Skip shift solenoid 30 Ft-lbs
Pressure plate to flywheel bolts 15 Ft-lbs then turn an additional 30 degrees
Release cylinder retaining bolts/nuts 1998 and later 71 in-lbs
Master cylinder retaining nuts 20 Ft-lbs.
All I could find and these are out of an Haynes Repair Manual 1993-2000. Hope it helps you out.
Originally Posted by getsomebeyatch
Sweet youll love that clutch i know i do, Where you been at all summer havent seen you around? Did you ever get those annv stripes?
