Southside of Chicago
#825
#826
I'd look into a Cheetah or something with a short stick and a short throw like that...If you want it in the stock location.
The Prostick/QuarterStick is so tall we actually build a box that mounts them about 1.5" lower than the fox-body floor(in the stock t5 hole). You'd probably have to try something like that in the f-body if there's room in the trans tunnel.
#828
The shifter is so tall it wouldn't feel right at all.
http://finalroundperformance.com/ima.../IMG_0052b.JPG
#829
Location: where ever i can store my car. (palos hills,il for now)
ok how does the cheetah shifter work? do you have to move it around the point (looks like between 1 and 2 gear) or does it move itself? sorry if that make no sence i don't know how to explane it better.
#831
I dont have one but im pretty sure that it works the same was as a normal shifter but when you pull back on it for the rev manuel valve body it moves side to side on its one so you just have to keep pulling back.. im not possitive on that but i did hear it somewhere i just cant remember
