Another Hall's deal!!!
#662
Massey, are you still using the timing tuner with the N2o setup? I bet it will feel great up top with the NANO system, no fall off over the run. Should be easier to tune "on the edge" as far as timing, more consistent I imagine.
If you can't hit 9 on a good day now (rear end willing!), something is wrong. What gears did you go with?
I'm still using it, but I think Chad took the additional timing (due to the larger nitrous shot) out of the tune, not with the timing tuner. I haven't talked to him since the retune. I was going to go get it today, but I accepted some overtime instead. Gotta pay to play! Chad has a prototype (again) Autocal unit he's playing with. Once the kinks are worked out, then I can do a killer NA tune as well as a tune for nitrous (175, 200, or whatever). They can store 8 tunes, so I'll have plenty to play with.
Went with 3.73s. Considered 4.10s, but after doing the math, decided my mph goals would be turning too much rpm for my taste. I figure 3.73s would have me around 6200 @ 140, so I still have some cushion IMO. I didn't want to sacrifice highway drivability over ultimate track performance.
#663
Good deal, just got off the phone with Midwest Chassis...the rear end and all the goodies are ordered, I also ordered my ABS/TC delete from SJM. I will be ordering the Nitrous System as well which leaves only the dual intank fuel setup; however, the tank will need to be dropped so that I can ship my sending unit to Nasty Performance for the upgrade.
#668
Does anyone happen to have a set of nice rims for a 01 Camaro sittin around they want to sell?? Looking mostly for z06 or zr1 rims. any offers are cool cause my wheels are terrible. thanks!
#669
Hello,
I am looking for a set of 17" wheels and drag radials that are in good shape to put on my 02 SS. If anyone has some for sale, please PM me.
Thank you.
Thank you.
#671
I believe steel but I'm not for sure. I know up to 01 they were steel which is why a lot of guys go after market...for the increase in diameter as well as less rotating weight.
#674
they should do a 100mph to 0 race, ill be down for it with my little 4 cylinder. i call it a braking contest.
#675
