C6Z06, T71 Supra, 300zx, sprayd LS1, Procharged LS1, Terminators, GSXR-750, STi's
So an NA H/C Ls1 fox slightly puled a H/C 150 shot F-body... something seems wrong there, there cant be that much of a weight difference between F-bodys and foxs
Any more info on these setups?
A fox body coupe would be ~2800 lbs with that setup. The F-body would be ~3500 lbs. BUT, I agree. The 150 shot should take care of that. I guess it depends on the heads/cam chosen by each. If the fox has more cfm heads and higher lift cam and making more N/A hp and weighing less than the f-body, the 150 shot may not level the playing field.
LS1 fox has a big cam and bolt ons...makes low to mid 400's on motor and weighs 2800ish lbs. Fox traps mid 120's....on motor.
#33
Thats what I figured. Still suprising the F-body didnt pull on the spray. That Foxs setup sounds pretty good though. Gives me good indication of what I should be able to do with a cam in my ls1/t56 rx7. My rx7 should be a bit lighter.
#34
NITERIDERWS6, I have not made a good full pass with it yet the one run I did make was a 11.01@127 mph 1.71 60ft would of been alot better but i was sleeping at the light lol.
The next pass I BUSTED all five wheel studs I have not made it back yet lot of snow on the ground here right now she should go mid 10s.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#36
#39
#40
Thats my z28 in the vid...What you couldnt tell was how much I was spinning in cold *** weather on street tires...the race that didnt make the video was a 70 roll which I pulled the foxbody by 2+ lengths to 130...
His car weighed 2700 and change with him in it at the track...I personally weigh 240lbs and have no weight reduction..haha
