Lifter tick? or what?
Old Mar 18, 2009 | 08:53 PM
Medic/Z28's Avatar
If it didn't do any other damage, yes. If that's what it is. I would also replace push rods. Cheap insurance. Have you been driving hard or stomping on it? Oh and for the record I've used GC 0-30w for the longest time. I ran RP at first but had too much oil consumption. With the GC I only have to add 1 qt between oil changes.
Old Mar 18, 2009 | 08:55 PM
90TSiAWD's Avatar
I took it to the strip once, but the sound has been there for awhile just not reallly noticable until I changed my oil and before that I havent ran it hard in a few weeks.
Old Mar 18, 2009 | 09:03 PM
Medic/Z28's Avatar
Man its hard to say. Mine was loud and it came from the driver valve side. I even listened to it with a stethscope without the bell to confirm it was a valve train issue. During revs or while driving it would get faster not louder.
Old Mar 18, 2009 | 09:05 PM
90TSiAWD's Avatar
When I rev it, the sound goes away....i can hear on start up, idle and when the RPM's drop but thats from like 2K down.
Old Mar 18, 2009 | 09:07 PM
Medic/Z28's Avatar
Change oils. Check the plugs and wires. Try the simple stuff first. Although bad plugs or wires would through SES codes.
Old Mar 18, 2009 | 09:08 PM
90TSiAWD's Avatar
Ill probably switch oils tommrow and see what that does...would it hurt the car if I drove it and all it was was the oil making the lifters tick?
Old Mar 18, 2009 | 09:12 PM
Medic/Z28's Avatar
If its not a lifter issue no. Check the wires. Make sure they are all popped into the plug and the coil pack. If it's something in the valve train depends what it is. Keep us updated.
Old Mar 19, 2009 | 02:25 PM
90TSiAWD's Avatar
change the oil to castrol 10-40 no real change.
Old Mar 19, 2009 | 04:41 PM
2001z's Avatar
Originally Posted by ineedashortblock
If oil pressure is fine, run it.
My motor makes all sorts of noise.
Not good advise if it a lifter taking a **** enless your wanting to spend some money. Your best getting that looked at before it gets worse over time. Sounds like a lifter to me
Old Mar 19, 2009 | 05:07 PM
ineedashortblock's Avatar
No doubt, but 9-10 this forum lives off scare tactics and you send people on wild goose chases.
Old Mar 19, 2009 | 07:33 PM
2001z's Avatar
I didnt send him anywhere he came on here looking for advise . what kind of advise is dont worry my car makes a ton of noises that it is normal?? And just becouse you have oil pressure doesnt mean all is well.
Old Mar 19, 2009 | 07:43 PM
  #32
90TSiAWD's Avatar
Update drove it to the GM dealership to have it looked at and well guess what it stops making the ******* noise until i get back onto base. Why would the noise be getting quieter then louder? just a sign of the lifter going bad?
Old Mar 19, 2009 | 10:45 PM
  #33
Z28LS1camaroguy's Avatar
i have a tick on the drivers side but its not the lifter, its that damn EVAP canister. Check that first cause it sounds like lifter tick but its just a check valve for fuel vapors.
Old Mar 19, 2009 | 10:51 PM
  #34
90TSiAWD's Avatar
How would I check that?
Old Mar 23, 2009 | 06:03 PM
  #35
90TSiAWD's Avatar
The sound is intermitent is most noticable on start up....and goes and comes back randomly.
How do i check that EVAP again?
Old Mar 23, 2009 | 08:19 PM
  #36
OffspringZ28's Avatar
wait what. more details please.
Old Mar 23, 2009 | 08:22 PM
  #37
my car sounds identical to the car in the vid. driver side too.
Old Mar 23, 2009 | 08:25 PM
  #38
90TSiAWD's Avatar
Is yours intermitent like mine? how long has it been doing it?
Old Mar 23, 2009 | 10:28 PM
  #39
Ryphraph's Avatar
When mine was making a lot of noise due to the loose plug, it didn't throw a code until it fell out...
Ryph
Old Mar 24, 2009 | 09:11 AM
  #40
Yea, it's intermittent. Been doing it since nov 08. Car drives fine with great oil pressure so I dunno.
