My trans am 0-145 run.
http://www.youtube.com/watch?v=2C47VCeLdgY Figured I might as well post this up since the cam has been done. Let me know what you guys think and if it's pulling good for the mods done to the car. Thanks
Numbers yet? I see the 4??/??? but is that a guess or a secret?
That doesn't look like I thought it was going to. I just looked at my old video when I was only bolt ons and I got to 120 a lot faster..?
here is a video. this is with stock a4 and 3.23's. car made 411hp thru a tci3500 stall unlocked.
http://s64.photobucket.com/albums/h1...urrent=003.flv
20ish roll. traction issues.
http://s64.photobucket.com/albums/h1...urrent=004.flv
How much do your heads flow? I would understand your acceleration with most of the mods you have but not ported and polished heads, that's kinda shocking.
Get gears...you'll be a happier man!
IDK, it doesnt seem that much faster than my stock 02 ta, with bad shifting trying to hold the camara
http://vids.myspace.com/index.cfm?fu...deoID=57962656
And yes 3rd did grind, if you guys would read the info on the side on the video... it says the tranny is on it's way out and thats why im shifting slow, im trying to make the tranny last as long as it can until i get money for a rebuild, the syncros in 3rd are going out badly. and im not ******* sure what's wrong, I don't get why it isn't faster as alot of the videos you guys showed are running at.. gears shouldnt matter that much, it should be fast to begin with. What about injectors? could that be getting maxed out or something
