My Build Thread.........New Engine
Old Sep 23, 2010 | 11:00 PM
  #41
01ssreda4's Avatar
Yes the car is running the 10 bolt, freshened up with a ratech rebuild kit and Motive 3.73s. Stock posi and axles.
Old Jan 6, 2011 | 05:36 PM
  #42
MasterTomos's Avatar
Damn that sucks about the motor. I think some nice fuel rail covers would really break apart all the silver nicely when you get it back together.
Old Jan 6, 2011 | 06:13 PM
  #43
01ssreda4's Avatar
You think? I have really been considering this also. Guess great minds think alike.
Old Feb 11, 2011 | 04:02 PM
  #44
Sykokilla's Avatar
Its all good man, I believe mine has had the same demise. Except it messed up my new build on the dyno.
here's the thread https://ls1tech.com/forums/generatio...tg1-0-a-2.html
I am pulling it now just need a saws-all to cut y pipe and unbolt kmember and trans crossmember.
Old May 13, 2011 | 02:27 PM
  #45
00pooterSS's Avatar
Originally Posted by 01ssreda4
Car had a decent tune on it, it did likely needed to be touched up/fine tuned but it ran great. I only turn about 6200 rpm so I wouldn't think that would be the problem either. It appears like a rod bolt failure.
You put in ARP rod bolts.... did you resize the rod ends after the bolts or did you slap in rod bolts and hit the road?
Old May 13, 2011 | 11:29 PM
  #46
01ssreda4's Avatar
In retrospect it may not have been a rod bolt failure. Who's to say at this point. Doesn't really matter anyway.
Old May 14, 2011 | 10:31 AM
  #47
00pooterSS's Avatar
It doesn't but I stumbled upon your build threads somehow yesterday and read this one. I had a bad feeling when I saw the pics of the ARP rod bolts then saw that you posted it came apart. If you install ARP's and don't resize the rods then you get kabloooey... as you already now know.
Old May 14, 2011 | 10:46 AM
  #48
01ssreda4's Avatar
That block/rotating assembly was rebuilt back to stock specs (i.e. stock pistons, rods, and crank were reused) by a machine shop It was done by someone else and i bought it like that. I did verify all the bearings were in fact new Federal Mogul. Among the plethora of unknown variables, shoddy machine work, rotating assembly out of balance, tuning issues, unknown other issues....there is no telling what that failed motor's secrets hold. At this point i can't hold anything accountable because I plain don't know how/why it failed.
Old May 14, 2011 | 10:49 AM
  #49
00pooterSS's Avatar
Oh I see. Sucks to hear that. Oh by the way your interior build thread is awesome, those seats look great.
