New exhaust on the Maro
As far as the exhaust putting heat onto the tire, it's not going to be a big deal. When you're moving under full throttle, which would be when the car puts out the most heat, most of the heat is going to be moved by air out the back of the car.
When I put my turndown on my cutout to kick it to the right, I noticed less drone and a bit deeper tone inside the car.
Thats what I thought you meant, lol
![](http://i8.photobucket.com/albums/a46/00ss4780/100_1305.jpg)
00SS4780----That set-up looks AWSOME!!. How did you get it mounted so close to the bottom of the car and where did you get that mount/strap used to hold the dump steady at the turndown?? Did you mount it all by yourself or did you have a shop? Also what kind of paint did you use? Heat Resistant?
Me and a buddy of mine did it. Everything is in stock location and just used a strap from Advanced Auto to pull the back up nice and tight. I used Heat resistant flat black. It smells the first time you fire it up but goes away after that. PM FullForce on here, he can make you 1 and sent it too ya. I know he has made some for other people on here and on his car.
#34
Doesnt matter what exhaust your using
My true dauls dumped were wwwwwwwwwwaaayyy quiter at part throttle than my open y pipe.
