Viper Steel Gray SS
#41
na dont have any pics of the car with the doors open. but pretty much everything is painted except for a couple little parts you'll never see. like under the car and behind it inside panels. but all the jams are done. hatch is done, t-top area. etc.
it has an incon twin turbo kit on it
oh i see..must b a blast to drive
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#43
The color looks awesome, always been one of my favorites. And so do the wheels and the FI setup....but like mentioned already all the wires take away from the setup.
Ever consider doing the wire and hoodlatch mod and TC relocation? I finally did it last month and can't believe I waited that long.
Also like mentioned, you could just unhook your amp wire from the battery, trim it shorter and run it off the driver's side aux post. Or if you want to keep the wire connected directly to the battery, you can rerun the wire down the passenger side, there is a grommet on the passenger side under the PCM....Mine is run off the aux post and just ran it with the hood latch cable when I relocated that so its one less wire seen.
#51
Honestly, this is the first gray/gunmetal paint I have seen on an F-body that doesn't turn lavender in the light like the old LT1's did.
If you take out your engine in the future don't paint it black, go find Duplicolor paint that matches and shoot it yourself. It's pretty easy especially if you have nothing in the way.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
btw OP, the SS looks SICK
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
