Build Pics
It's a 1997 Camaro Z28. Previously had an LT1 and now I am dropping in an LS motor. Anyways... here is what I got, LQ9 408 stroker. Trick flow 225cc heads, FAST 92mm Intake, Nick Williams 92mm TB, custom voodoo cam and 1.7 rockers, Lingenfelter 100mm MAF, FAST 42lbs injectors, Fast Toys 104mm air lid, ATI Damper, Mezeire electric water pump, manual rack and pinion, TCI magnet starter, and the suspension is all from BMR (a-arms, k-member, control arms, etc.., etc..). The tranny is stock 4L60E but rebuilt with a TCI 3000 stall. I've got a BMR torque arm relocation kit with adj. torque arm going to a Strange S60 w/35 inch spline axles w/3.73 gears. Custom valve covers from my engine builder (Golen Engine Service) w/Thunder Racing coil pack relocation kit. Custom tune by PCM For Less. (Thanks Bryan!!). Sorry so long, but that's what I'm working on. I will post some pics of what I've done so far. Now I will hopefully be able to at least keep up with the Houston streets. Later guys!! Trending Topics
I am planning to buy a hardtop, M6 93-97 Z28 to do an LS swap in. Just need to find the right one.
If you are in Houston and looking for the car scene, check out www.houstonperformancedriving.com A lot of cool people and fun events.
