The Fastest Shifting I Have Ever Seen!(FIXED)
Old 11-07-2010, 08:09 AM
Administrator
unit213's Avatar
Originally Posted by Marc 85Z28
Did you bump your head?
Nope. I was specifically referring to a Liberty as mentioned above. There absolutely is a clutch. Are you telling me there's no clutch? Did you bump your head?
Not that I've ever owned one, but I know how a Liberty works. A good friend used to run a Liberty in his Outlaw 10.5 car. I'm familiar with the setup.
I think we're saying the same thing anyway...just semantics. Anyway...back on track.
It's definitely not as impressive as really rowing gears when you're running a faceplated T-56 or a proshifted setup.
Old 11-07-2010, 08:28 AM
Heater's Avatar
Liberty's are so bad ***
Old 11-07-2010, 08:37 AM
Administrator
unit213's Avatar
Hell yeah they are!
Old 11-07-2010, 10:02 AM
Build #1's Avatar
They probably are all faceplated, but not air shifted. Look at other videos of them and they shift just a hair slower in some.
Old 11-07-2010, 11:10 AM
Marc 85Z28's Avatar
Liberty calls it a clutchless transmission, you can argue the name with them.
Old 11-07-2010, 11:50 AM
88blackgt's Avatar
more sex
http://www.youtube.com/watch?v=ygYw8xec6ck
Old 11-07-2010, 03:14 PM
***Repost Police***
Irunelevens's Avatar
Originally Posted by Build #1
And here is another
[youtube]qyV28UHrhzQ&NR=1[/youtube]
Wow... shifting while the car is on 2 wheels
Wonderbread is the Man
http://www.youtube.com/watch?v=R1W9q...eature=related
That Is All/
TAD is where I run
Old 11-07-2010, 04:13 PM
OUTLAWZ RACING's Avatar
You need ***** of steal to race at Temple Race way( TAD). That track sucks bizzalls.
Old 11-07-2010, 04:22 PM
***Repost Police***
I know it's not too bad when you have a slow car . That's where I ran the fastest time in my old Integra, which was the 2nd fastest ever time for a stock GS-R. So it's not THAT bad.
Old 11-07-2010, 08:25 PM
97'RS6-BucketTurd's Avatar
A clutchless manual trans? How would that work? There definitely is a clutch.
I realize there is a clutch.
That's just what Liberty calls it/refers to it as.
http://www.libertysgears.com/index.html
Second link down on the left hand side, "Clutchless Transmissions".
(http://www.libertysgears.com/clutchless.htm)
I agree, it is misleading to those who aren't familiar with them.
I don't know of any sites that give a good explanation on how they work, otherwise I'd post it for those who are interested.
I'd like to see a step by step animation of the shifting process my self - seeing as how I'll most likely never be able to afford one.
...Unless someone wants to purchase a set-up for me?
Regardless they're great transmissions and I'd love to own one...or even have a friggin' vehicle worth putting one in for that matter.
I'll settle for a ride in a car equipped with one?
Old 11-07-2010, 08:32 PM
bayer-z28's Avatar
I know faceplated, but the other stuff is new to me.. (And I've been around this stuff for a WHILE too.. )
Originally Posted by 88blackgt
This is just frickin nuts..
Old 11-07-2010, 09:11 PM
  #32
67 LS1 Vert's Avatar
Guy in the last in car video has major compulsive disorder. He checks to make sure it was in neutral 12 times after the race! lol
Old 11-07-2010, 10:07 PM
  #33
speedshifterNC's Avatar
the only way to drag race is bangn gears...love it
Old 11-08-2010, 03:21 AM
  #34
glhs422's Avatar
Originally Posted by 97'RS6-BucketTurd
KFC is referring to the 'wonderbread' mustang in the last 2 videos, if i do recall he used a liberty clutch-less 5 speed in that car? (please correct me if I'm wrong)
Regardless it's fast and it gets **** done lol
Props to the driver in the second video, nothin' but sky and bangin' second gear!
Hang'em and Bang'em!
I remember a bunch of drama about his vids... apparently they were sped up. Either way, it's still some gnarly shifting...
--Eric
Old 11-08-2010, 12:00 PM
  #35
2fast02TA's Avatar
The first couple of vids looked like cars from the NMRA class that has to have a 5 or 6 speed in it. (I used to run around with a friend that raced in the NMCA.) They are clutch cars and they do bang some gears. Beleive its called "Real Street"
This is out of the NMRA Rule Book
2: DRIVETRAIN
2.3 CLUTCH
Standard Ford OEM factory-replacement-style single disc diaphragm clutch required. Steel or aluminum pressure plate a minimum of 10.0-inch in diameter is required. Adjustable pressure plates, or long-style pressure plates are prohibited. Clutch operation must be operated using factory style cable mechanism. 2005-up Mustangs using hydraulic clutch actuation may retro-fit ’79-’04 cable style mechanism.
Old 11-08-2010, 12:17 PM
  #36
Camaro_94's Avatar
Originally Posted by 06X6spdGTO
Gotta give props to the second vid!! 1-2 Shift with the nose lifted and still carry it out!!!
Agreed! That was insane!
Old 11-09-2010, 08:27 PM
  #37
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Fastest TBSS ran 9.03@150 there this weekend without a parachute
Old 11-09-2010, 11:24 PM
  #38
HioSSilver's Avatar
Originally Posted by $750 L98
I wish I had a 6 speed to mess with, I used to be pretty quick, absolutely nothing like rowing the gears as fast as you can. Were they not using the clutch? Is that what the odd noise was?
That odd noise is probably a ignition cut via load cell on the shifter allow them to shift without lifting. It is unloading the trans for milliseconds. Our roadrace cars had this feature and that same pop sound....I need a load cell shifter for my faceplated t-56, I don't use the clutch to shift it.
Old 11-10-2010, 04:20 AM
  #39
DoggyB22's Avatar
Wish I could afford one of these!
http://www.youtube.com/watch?v=jUSPwmN9MWE
Old 11-10-2010, 07:00 AM
  #40
HioSSilver's Avatar
We had sequentianls in our road race cars they are bad ***, I'm surpised that not many use them in dragracing. I guess it's still pretty high dolla stuff.......that vette should've been faster.
Quick Reply: The Fastest Shifting I Have Ever Seen!(FIXED)
