First start up of EPS 234/246 Cam
I talked to Geoff at EPS and be both agreed on since I am looking for good N/A power and track performance but told him I may spray it he recommended it since I am not going to really go over a 200 shot after I learn to tune properly on a 100 and 150 hit, If It was going to be track only Nitrous car I have no doubts he would have recommended something else and specd me a cam. So this cam will work good with nitrous with that big split in duration just wouldnt be optimal. Hopefully I will find out.
It cool man 602/607. Geoff is a cool guy to talk to and get alot of info from him. It is a all motor cam but It wont be a large hit of the good stuff. Only thing that sucks is I would have to change rear gears 4.56s would be a little steep. Hopefully 4.10s would work with 28 inch tire.
Yep i think 4.10's would b a good combo if u spray..should have prettydecent results N/A with the 4.56's..cant wait for ur results with tune and run ur current set up! IMO I think a better gear N/A would b 4.30's..just sayn..
#36
I am sure it will cook down the track. I ran my 12.0 with mostly only 2nd and 3rd gears, 1st gear is not holding in my TH400, so if the cam has enough power to push a 2-Ton car down the track at 12.0 only using basically 2nd and 3rd I cant wait to see what it will do once I get 1st gear fixed.
