Rage R200T (zx14 powered buggy) in the snow! Must watch
Thing looks like a blast to drive. More info on it here http://www.ragemotorsport.com/shop/c...?cpid=custom47
"The Rage R200T has taken the concept of the Rage R180T a step further. With more power and even more torque, this machine will blow your mind. It is obvious at first glance that this is a Rage, but drive it and you will see that this is something even more special.
Again, it is an incredible vehicle that is capable of operating on a variety of surfaces, ranging from tarmac race track to full motocross.
It is powered using the engine from the latest Kawasaki ZZR1400 Motorcycle, and can be specified with either a new or used engine. Used engines are all low mileage examples and come with a full warranty.
As the name suggests the R200T has around 200hp which is delivered to the rear wheels via our own fully enclosed drive system.
The R200T comes in motocross stance as standard, and can be converted to Supermoto within 15mins using the Supermoto kit (optional extra), comprising of tarmac tyres, alloy wheels and shorter shock absorber springs.
The 1352cc engine gives incredible performance and will launch from 0-60mph in around 3.5secs and on to a top speed of 120+mph.
A sequential gear shifter mounted to the side of the steering wheel operates a six speed gearbox, and there is a fully mechanical reverse gear too.
A conventional pedal layout is used, with accelerator, brake and clutch being foot operated. The brake pedal is designed to allow either right or left foot braking, as required."
