Testing at track with Cam. 1.41 60'
Old Jun 4, 2013 | 11:59 PM
04BlackGmc's Avatar
Default Testing at track with Cam. 1.41 60'
Finally got time to get to the track and do some testing and Trans tuning at the track since the car won't hook at all in first on the street.
Car is blipping the limiter on the 1-2 shift and killing timing but besides that im happy with the direction of the car.
Hoping to get back again soon and make some full passes.
Breakdown of mods
Vengeance Racing KAOTIK Cam
235/243 .621/.624 113+2
Yank PAS3800
FAST 102
ARH 1 3/4 LTs
3" Xpipe with 3" Zo6 mufflers
Vararam CAI
315/30/18 Hoosier Drs
2.56 Gears
Old Jun 5, 2013 | 01:48 AM
ajrothm's Avatar
Car is leaving damn good! 1.41 60' with 2.56 gears is hilarious.. Other then the 1-2 shift/limiter , it looked like a good pass.. Did it go in the 10s? Did the mph come around where it should be with the cam change?
Old Jun 5, 2013 | 07:57 AM
04BlackGmc's Avatar
It was only 1/8th mile that night that's why i went out to just get the car lined out. 6.83 in the 1/8th and 99+ mph. I know there is still some improvement left. Hoping it has some 6.7's at 100+ in it.I knoiw it should start moving on the top end pretty good with the cam so i need to get some 1/4 mile passes in.
Funny thing is i pulled my 10.55 timeslip my old G8 that always seemed to really start pulling after the 1/8th and that car was 6.84 in the 1/8th
Old Jun 5, 2013 | 07:57 PM
ajrothm's Avatar
6.83 comes out to a 10.72 using a 1.57 back half correction.
But real world, when my 71' runs 6.80s@100-101mph, that is usually 10.70@125 mph.. I went a 6.74@102 and it was a 10.59@127.52. That was a 1.51 60'.
Your car is definitely gonna back half better then my 3700lb tank but...extra mph doesn't always show up in the ET..depends on how your converter is on the back half as well..
I think your car will run 10.70@126 in the same conditions you had the other night... Not to mention you lost .05 from the rev limiter 1-2 shift.. Get that fixed and get some good winter air and you'll go 10.50s at 128..
Nasty *** ride for a cam only deal... That's for sure! Keep at it!
Old Jun 5, 2013 | 08:51 PM
sabersaw30's Avatar
Wat rpm you launching at?
Old Jun 5, 2013 | 08:55 PM
04BlackGmc's Avatar
Yea im hoping to get it back once some cooler weather rolls in again.
I think i have the 1-2 set down far enough on the tune i wrote after the track but i'll see.
I'm figuring the car should trap 125-126 like you said. I was down to 121 before the cam with the 3800 stall
Foot braking to around 2,000 and letting it flash the rest of the way.
Old Jun 6, 2013 | 03:27 PM
Zmg00camaross's Avatar
Damn thing is running good cam only. Put a lower gear in it bet it be 1.3x 60ft times.
Old Jun 15, 2013 | 08:34 PM
04BlackGmc's Avatar
All the guys on the Corvette forum tell me to put some skinnies on it and pull the passenger seat and see some 1.3x
Old Jun 16, 2013 | 09:10 PM
LilJayV10's Avatar
Very nice. Why the 2.56 gears?
Old Jun 16, 2013 | 10:53 PM
04BlackGmc's Avatar
Stock gears that came In the car.
Old Jun 16, 2013 | 11:03 PM
LilJayV10's Avatar
Wow I had no idea. Shows how much I know about vettes.
