Finally got to teh track
left lane him.....Right lane me
RT .056.................128
60' 1.672...............2.038
330 4.944...............5.357
1/8 7.725...............7.799
MPH 88.03...............103.25
1000 10.157..............9.805
1/4 12.250..............11.590
MPH 107.03..............122.18
Edit: sorry bout all teh periods. IT wouldnt let me space the 2 columns out.
As ya can see i had him by 15 mph in teh 1/8 adn the 1/4. This is cause i needed to go into 5th and my 5th synchro si screwed so i wasent able to get it in at all. U can see in teh vid where i tap the brakes when i miss the shift. Its right before the concrete wall next to eth car gets taller. On the way home i used hptuners to see how fast i can go in 4th adn i do 132 at 6700 adn that is where i tried to shift into 5th. So this sunday hopefully ill get it into the 10's before winter. Thanks
http://video.ls1tech.com/player.aspx...D-3C2D93275879
John
John
John
so you mean your were in 4th doing 132mph, then went to shift into 5th and missed the gear?
I shift at 6k for all gears but 4th as i was hopin to get across theline in 4th. I definatly wanan get away from 5th. The reason i have 3.73 is that when i do get clicks ill get 28"ers and be right where i wanna be as far as rpm goes.
And yes i went all kept in 4th till 6700 and then shifted adn it didnt let me in 5th. I didnt end up gettin in 5th. Sux 4 me!
John
4th -> clutch to neutral -> clutch again to go into 5th.
may take a little longer, but it will let you into 5th.
that would take way too long, and the rpms would fall fast from shifting to 5 gear from 4thgear at redline.
double clutching is for downshifting and involes a "blip"...hence you dont lose anytime because you are on the brakes while your shifting.
i had this prob shifting from 3rd to 4th and the tranny would lock. I was told i just needed a new clutch to handle the power.
John
