C5 FRC on Bogart D10 Bigs and Littles!!
I love the bigs and littles on corvettes. Heres mine with CCW's. I will be running Weld Magnum drag 2.0's in about a month. So it will look like Pauls black one but mine is Pewter.
![](http://i45.photobucket.com/albums/f63/gtformula/DSCN0442.jpg)
![](http://i45.photobucket.com/albums/f63/gtformula/exterior3.jpg)
Well I know from personal experience there is no way possible for a 15 inch wheel to fit on the back of a corvette. I inner wheel diameter is too small to clear the top of the spindle and you would have to grind off a 1/2 an inch of material from the lower control arm. The fronts are not as bad you can get 15's to fit but you will need to get a wheel that is specially made to clear big brakes. I went to mount my Magnums and the brakes were bigger than the inner wheel so there was no way. I went ahead and bought Strange drag brakes . Now no problem. Also Im putting in a solid axle so the 15 inch rears will fit.
#40
I'll talk to steve @ sjm and see if he can still make the 16" for the vette. It takes rear fbody brakes on the front to get the 15" to work. I'll try and get some pricing on this combo if you guys are interested.
