C6Z Doing Near 200 MPH
Here's it's complete gearing taken straight from chevrolet's website
1st 2.66
2nd 1.78
3rd 1.30
4th 1.00
5th .74
6th .50
3.42s with 7000rpm limit which most of you already know.
Full out in 5th at 190-200 mph sounds UNBELIEVABLE!!!
If you haven't experienced that beautiful sound from an LSX-based, modified ride . . . then I HIGHLY recommend it!
Believe me . . . it sounds VERY different from WOT in any of the 4 lower gears
That vid also makes me miss Eastern Europe
1st 2.66
2nd 1.78
3rd 1.30
4th 1.00
5th .74
6th .50
The C6 ZO6 can, theoretically, hit 200 mph LONG before it's 7000 rpm redline
With it's tire and rim sizes (which happen to be far larger/taller than our F-body, or even C5 sizes) the C6 ZO6 should, given enough power (which it lacks), achieve 200 mph somewhere around 6400 or 6500 rpm's in 5th gear.
The C6 ZO6 more-than-likely lacks the necessary power, stock, to achieve the magic 200 mph at it's stock drag area.
IMO, everything else being stock, a remapping of the PCM should give it the necessary power to crack 200 mph.
Full bolt-ons and a tune then it's a matter of how far past 200 mph will the C6 ZO6 go
On a side-note, 186 mph is the supercar top-speed standard in the rest of the world
In Europe and other countries, the base C6 is considered a "supercar" because it can achieve 186 mph stock
I personally don't consider a car a supercar unless it can achieve OVER 200 mph in a head wind
As I stated, the drag area of the C6 ZO6 requires a certain amount of high rpm power to achieve 200mph.
Even though GM has stated that the C6ZO6'S top speed is 198mph, I'd imagine it's probable with at least a 5mph or greater tailwind and a LONG run-up of highway.
In your original post I thought you were implying that the stock C6 ZO6 would run out of gear in 5th; which obviously is not the case
Questions like this wouldn't be asked if one knew the requirements for passing the German Driver's License Course.
Many people in America are clueless to stringent Highway Laws and the EXTREMELY strict fashion in which said laws are enforced in Germany
Just a SINGLE little example . . . virtually everyone on the highway here in the US would be ticketed for traveling too close to the driver in front of you
Even during heavy-flow traffic times like 5 o'clock rush hour; there is no such thing as "bumper-to-bumper traffic" in Germany on their highways . . . because that's illegal. A certain distance must be maintained and adhered to at all times to any vehicle in front of you.
Slower traffic MUST travel on the right. Most slower traffic travels ~120 mph in the "slow" lane (you'll notice that the rate at which the 'Vette passes the "semi" does NOT look like it is traveling ~60 mph if the 'Vette is doing near ~200 mph).
Yes; I have some experience on German highways.
