This thing defies physics. 1000+HP helps.
Buggatti-10.4 @ 143mph $1,300,000 & 253mph top speed.....
In case you didn't know Veyrons top speed is electronically limited.
Saying that it will beat Veyron is the same thing as saying Veyron is coming out with a 1250 hp 275 mph version. Who cares even if it does go faster id rather be traveling in a safe car at 252 than the death trap at 260.
Is there a point to this?
We should compare more race cars to Veyron. Formula 1 the best daily driver of them all beat the Veyron!! Maybe we should compare Veyron to a funny car to make fun of it getting owned in a straight line.
Every little peice of the car is 100% forged billet meterials. This includes everthing from engine components to blinker stocks.
The 253 MPH rating is GOVERNED ( I can't believe no-one mentioned this) and 253 mph is set because its a reliable top speed that the owner can achieve. Engineers state aerodynamically, the vehical will lift off if it was allowed to attain a higher speed.
The amazing attention to detail, and severe engeneering tests proformed on this vehical are simple outstanding... No other car in the world will ever be able to compete with bugatti's rarity any-time soon. The Saleen is a race car, the Buggatti is a driver, opposed to what was stated above.
I don't think any-one can ever understand these cars untill they are face to face with one. Its simply outstanding, and awe inspiring. Getting back into your run of the mill camaro or corvette you will realize just how shitty these cars are in comparison. Even the saleen, which was just built for going fast, looks like trash parked side by side.
In this aspect you look at fit and finish, as well as speed. I don't care if the car wieghed 9,000 lbs and had 4 trillion HP. I have had enough luck to see two of these machines in person, and I was baffled at how perfect it was placed togeather.
Saying S7 owns a Veyron is as retarded as saying Big Block Chevelle drag car owns the new M5.
Wow Honda F1 car reached 258mph with minimum aerodynamics, thats soooo impressive considering it weights 3 times less than a Veyron. Oh yeah that Honda is also a daily driver and affordable.
Wha? Read my post again. I wasn't COMPARING an F1 (not a McLaren F1...a Formula 1) car vs a Veyron at all.
So where you got that from i have no idea. I made mention that simply weight doesn't keep a car planted at high speeds, aerodynamic down-force is an amazingly important factor. And while explaining that i used an F1 car as an example, why? they have insane down-force.
And besides the Veyron or Enzo or Carrera GT can never be compared to an Mclaren F1 or even Saleen S7. Both cars have actual racing provenance. They weren't just some engineering exercise that have never turned one lap in competition.
I bet S7 owns Murcielago in everyway.
The Bugatti is amazing and would most likely be more reliable at top speed but who is really going to see those numbers consistently, I still
